Improved front license plate bracket?
RubyLynn
NY
2016 Fusion
We stopped at our dealership today because their website showed that they had a 2 door on the lot. It was in the sold row but I noticed the front license plate bracket wasn’t as horrible as the factory one. Maybe they improved it? Or the dealership had these on hand? Either way this one isn’t too bad, it doesn’t cover any part of the grill. I think I can live with this one!
Ford Bronco Improved front license plate bracket? 7AF19D69-1BD1-43E2-B657-15F8AA7BE88C
BUD
Boston
Lancia
I believe the difference in location depends on the bumper. The steel modular bumper puts the plate mount higher.
ny176
Outer banks
Nissan Altima, 3 series,Bronco 2 door outer banks
Wait a min, are you saying that they put the front license bracket on from the factory? I thought the dealership usually installs it. I was planning on contacting the dealership to specifically not install it
campbebc
Ben
Waterford, VA
2021 Ford Bronco, 2019 F-150 Raptor, 2004 Mazdaspeed MX-5
Dealer installs it
RubyLynn
RubyLynn
NY
2016 Fusion
Ok, gotcha! Didn’t even think about that. 🤦🏼‍♀️
20Bronco21
Amidst the Cornfields of Illinois
‘23 Balands ‘24 Bronco Raptor
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Without a doubt, these are a tremendous improvement over what Ford has conjured up. Well worth the money, and will fit the standard bumper with a couple of holes drilled.
Don't forget to also add a license plate to both recovery hooks, for a more "in your face my-vehicle-is-registered" effect :ROFLMAO:
@HBTFD's front mount is awesome. Can't wait to install it one day on my Bronco. Also easy enough to remove if I need the extra clearance.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
HBTFD
Newnan GA
F350
Seems like that would be one of the first things torn off when you go wheeling
On the plastic bumper no license plate is going to survive serious off roading. The plastic or fasteners will fail before the bracket. With a set of wing nuts removal takes less than 60 seconds.
  • Like
Reactions: Cat
Rubicon 2 Badlands
San Ramon, CA
2008 JKU Rubicon / 2021 Bronco: Badlands/Sasquatch
License plate finally came in so I could use my new mounting bracket. Looks great! Thanks again for a much better option!
Ford Bronco Improved front license plate bracket? 49E2EBC2-D9DD-4B3C-9024-1B16EDE01720_1_201_a
