HVAC Vent Whistle
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Bump... any update on a fix or TSB please?
Hi there. This vent whistle concern doesn’t sound like something we want you to experience with your Bronco. Could you please send us a PM with your VIN and the name and location of your Ford dealer? I'd be happy to look into how I can assist you on my end. To send a private message, just click on our username and select "Start Conversation".
Aburgess
Amber
Washington
Nissan Sentra
Has there been an update with this issue? I have it as well. I have taken it to the dealer twice and they can’t replicate the issue. But my passengers notice it when we drive at highway speeds too.
PizzaMan
Rocky
Roswell, GA
'21 FE Cactus Gray; '22 GMC Yukon AT4;
Any updates here? I wasn't allowed to send a DM to Ford via the direct message feature somehow. Thx!
Same issue w/ my ‘21 FE. When the heat is on and the floor vents are routing the air, you hear a whistling /him that sounds like its coming from the rear.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
@Ford Motor Company is no longer monitoring these forums, that’s why. You’ll need to reach out to your local dealership directly.
BigBlue7
New Jersey
‘23 Black Diamond Sasquatch
If it is only happening when it is cold and when the HVAC is running, then it is likely a whistle coming from the weather stripping gap between the frame and the mid panel of the hardtop.
I had a similar issue happening last winter and the fix was some pipe insulation in the channel of of the frame (after taking the front three panels off).
PizzaMan
Rocky
Roswell, GA
That sounds like exactly my problem. We've been running a soft top for a bit but put the Hard Top on for the winter. The windows down makes the sound go away but it's any window. Primarily though the sound seems to be coming from the back passenger side. I'll look into this. Thank you!!
BigBlue7
New Jersey
Cracking a window neutralizes the cabin pressure so the air is no longer going between the hardtop seal and the frame to make the whistle noise.
More information here
https://www.bronco6g.com/forum/threads/cold-weather-wind-noise.105926/post-2407048
vbrad26
Vance
FL
VW's, an old Range Rover and now a Ford
So I'm just going to add this for fun but....
I had a whistling noise seemingly coming from somewhere in the HVAC system.
I can't remember anymore if it came and went with speed (I don't think it did) or if it came and went with fan speed (I think it was this)
Anyway, turns out my wife used the dial at the bottom of the far most right vent to shut it.
Once I opened it back up, the whistling went away...
