How's this for a non constraint build?
AuldBronco
Sean
Cape Cod
Ford Bronco Badlands Mansquatch
Finally gonna join the waitlist and put an order in August. I fully expect to it to take over a year, so ill patiently wait. Heres what I plan to order.
2.3 manual
Soft top
High package
Optional beadlocks
Non Sas
As far as i can tell, the only real constraint is the Badlands because of front locker maybe? I dont see much about optional wheels or high package being a constraint. This is actually the build i really want with no compromise.
Burgler2112
Andrew
NJ
2022 Black Diamond Bronco 2.3l Mid Soft Top
Do you not want a hard top ever?
my only suggestion would be if you think you’ll get one down the road, order it from the jump.
they are delivering plenty of hard tops and it’ll be way harder to get after the fact.
that’s my only regret with my purchase, I thought I’d just get it after and who knows when that will even be possible or how much it’ll cost.
AuldBronco
AuldBronco
Sean
Cape Cod
Im kinda up in the air about it. I dont think id mind the soft top at all, but i do realize its gonna be a fortune for hardtop after market. And i drive big dumptrucks for a living. Noise isnt really an issue for me in the cab, lol!
Stitchxp626
Chuck
Lancaster Pa
Subaru Forester 2006
I'd skip the bead lock wheels, get the steelies and buy after-maket wheels of your choice - the bead-locks (I thought they required Sasquatch?) appear to be a constraint item as well...
RHeinz
Ric
Houston, TX
I’d recommend getting whatever you want, damn the constraints. No one can predict what will be constrained a month or a year from now, so why try. The 2.3L engine plant might burn down next week…..
I waited 318 days for a vehicle with nearly all the constraints except the tow package. Perhaps I was lucky. Get what you want to get and hope for the best.
Monho
AJ
Dallas, TX
Ford Escape
Badlands trim has the option to upgrade to a beadlock capable wheel without the Sasquatch package. They look pretty sweet imo.
AuldBronco
AuldBronco
Sean
Cape Cod
Thats what i think im going with. I dont have a need for the sasquatch and they definitely look much better than the stock badlands rims.
nabronco21
Nick
Pennsylvania
2021 ford bronco/2008 ford ranger
I wish I would have spent the couple extra bucks for them they do look good.
1970AMCAMX
Robert
Titusville, FL
F150, AMC AMX, DF Goblin
Only problem with the optional Badlands wheels is that they are still the 55 offset vs the 30 offset for the Sasquatch wheels which may limit your tire sizes (though I have seen the Sasquatch sized tires put on 55 offset wheels). I think you would be better off not getting the optional wheels and if you want the factory bead locks I would find a set of Squatch pull-offs (plenty of them listed on here without tires for less than $1000) then you could sell the stock Badlands rims to recover the majority (if not all) of the cost.
AuldBronco
AuldBronco
Sean
Cape Cod
Good point. But not even sure i want 35s at all.
