HOW-TO Install Yukon HD Diff Covers
Tech Tim
Tim
Wet Side of WA
Jeep JKU
Another install video uploaded. Although it is a Jeep, the rear M220 cover is the same for the Bronco.
@Tech Tim is at it again with another easy install video. This time around he shows you how to install the Yukon Gear HD Diff Cover for the M220 Rear Dana 44 axle. Now he is installing the diff covers on a Jeep, but don't let that bother you because the Bronco uses an M220 rear Dana 44 too, so the process is pretty much the same.
They are a quick and easy install and you can do it right in your garage or driveway with a couple jack stands and some hand tools.
If you need a HD diff cover for the back of your Bronco, take a closer look at the Yukon Gear covers. They are made from nodular iron for strength, feature conjured inner surfaces for better cooling and have a black powder coated surface for good looks.
Check out the links below to get Yukon Gear HD Diff Cover for your 2021+ Ford Bronco:
Rear M220 - D44: Yukon D44 Hardcore Rear Diff Cover, Black
Red Line High Performance Diff Oil: Red Line 75W90 GL-5 Gear Oil - 1qt
https://www.northridge4x4.com/part/gear-oil/57904-red-line-75w90-gl-5-gear-oil-1qt
