Holes (mounting points?) on rear of roll bar?
rguest3
Raymond
Florida and Virginia
F-350, F-450, 23 Bronco, 24 Raptor, (2) 77 Broncos
2022 4-Door Soft Top - 12/21 Build
2 Holes with Slot Between on Both Sides - Additional Holes - one on inside and one underneath.
Pothole
Shingle Springs CA
2018 E400,2016 Mstng GT conv, 2018 RAM 3500 dually
Here is a picture from a webpage. Does anyone know what these holes are for? 2 holes per side in the top of the crossbar about even with the front seats.
Ford Bronco Holes (mounting points?) on rear of roll bar? image
I I am thinking of using them for the front mounts for a kayak rack - custom make some adapter and install 1/4 x 20 jack nuts for the anchors.
Easy-v
U S A
BadSquatch
I have an idea using that mount t
let me know if you figure out a method of mounting something there
davidbitton
Bergen County, NJ
'22 Wildtrak
First off, the holes are M8. I use these for the door harness because I misplaced the ones that came in the package.
SamIdea(TM) 5-Pack M8 Stainless Steel Shoulder Lifting Eye Bolt Ring With Male Thread https://a.co/d/ha7kNGI
DD214
Western Mass
2018 JLU Sahara, 2015 Pilot, 2022 Bronco
I have been thinking of curing the bad interior lighting issue with these holes by figuing out a bracket that holds a rock light to these holds and using a switch on the switch accessory pack. I’ll bet someone with a 3D printer could bang this out.
wbrainbow
Bob
New York
1969 C-10, 2022 Black Diamond, 2007 Harley Davidso
This is the frame brace on the Raptor. It also has a brace above the rear seat.
Ford Bronco Holes (mounting points?) on rear of roll bar? E29FE055-6B19-4F37-9F54-9C25C4471575
UtahBrandon
Brandon
www.puravidaoffroad.com
a number of classics and my 4dr Badlands
I took a close up pic of one as well, curious if my traction boards brackets would fit. I think so.
Ford Bronco Holes (mounting points?) on rear of roll bar? BDC2149D-1748-48B9-B685-ABDEAD0DD6D0
TigerBronco
Charles
2011 F-150 F/X 4, 2019 Honda Odyssey, 2001 Nissan Pathfinder, 1992 BMY M923A2 M
Zero threaded holes on either side of my 2021 4dr. Blend date was 8/12. Wish I had them because I'd love to put the Bronco Raptor brace on.
Rockworkx
Grant
www.rockworkx.com
Jeep Rubicon
For those of you looking for a gear strap option for the D Pillar, we now have our M8 1.25 Thumbscrew along with a 20” gear strap available. 4 Door Broncos have multiple threaded mounting options, and the 2 door seem to only have 2 on the top side of the D pillar. We would love to hear if otherwise. We also have a 15% coupon code for Bronco6g users. “24Bronco6G”.
https://www.rockworkx.com/collectio...for-bronco-4d-b-pillar?variant=42738793906372
Ford Bronco Holes (mounting points?) on rear of roll bar? REd_B pilar gear stra
Ford Bronco Holes (mounting points?) on rear of roll bar? REd_B pilar gear strap 2
Biggwrm
Orran
Gilroy CA
2018 Raptor
Has anyone ever made a template and tried to drill and add the “missing” nutserts from the early builds? I have a FE and doesn’t have them unfortunately.
UtahBrandon
Brandon
I haven't seen a template but some of my customers have drilled their own holes for nutserts. Main advice seems to be to use a new or sharp drill bit as the roll bar is made of a very strong boron steel.
