Help decoding window sticker
88to21bronco
Tennessee
2017 Nissan Titan XD
My window sticker showed up yesterday. I know the "blend" number is the date of build. What other interesting info can I get from my sticker?
RPF
FL, HI
11 Raptor 15 Q70S/5.6 19 F-450 21 Bronco FE
The Blend number is the bold number to the right, it is related to it's place in the build sequence during the build week. If you look at any of the production videos, you'll see the build sheet taped to the hood and that number is displayed prominently on it. You will see this number on several of the stickers on components when the vehicle is completed instead of the VIN. Components are pulled to be installed on the vehicle based on this number.
Above the word BLEND is the build date in the format xYYYYMMDD. This code can also be seen on the certification label on the driver's door frame of the completed vehicle.
Other dates on the sticker are at the bottom of the sticker, about in the middle in a box. This is the date that the sticker was generated and the unit is considered to be in production. It is approximately 7 days before the build date.
The last date that can be found is on the bottom below the border, and that is the date that the .pdf file that you are viewing was generated.
noliveaxle
john
Riverside, Calif
2015 jku rubicon
Where do they post the vehicle ship weight.
BronchoPeat
Pete
Ohio
www.evergreenclothier.com
'18 Tiguan S w/4motion | '14 Fiesta SE Hatchback
The date on the bottom in the outside border hasn’t changed for me since 6/23. It probably doesn’t mean anything but just curious if anyone else the same thing happening?
