HAM Radio Antenna
Liquidtravel
Layne
Canyon Lake, Texas
2022 Bronco
Hello all,
I have read a great deal on this site about setting up a HAM Radio in my bronco but now I have a question. I want to put my antenna on the rear of my bronco but can't find an adapter that will work with a PL-259 connector. I have seen several that will work with a GMRS antenna but not a PL-259 connector. Does anyone have any suggestions?
thanks
kk7ama
Andy
Wyoming
2021 4dr Bronco Soft Top
I apologize, your question is somewhat vague. Does the end of your coax that is going to the antenna have a PL-259 connector, or do you have an antenna with the UHF (pl-259) threaded base?
I am not sure if this helps, there is a NMO to SO-239 adapter for this type of antenna here:
https://www.dxengineering.com/parts...zisO9qD6uUHUf-nO46qig8bUfaV0eHrhoCOzcQAvD_BwE
Or, if your coax is terminated with a PL-259, here is an adapter that you could use to convert to NMO antenna:
https://www.americanradiosupply.com..._FKTBPEdO4cyNCS-sKO_Bk13ZYORnwMhoCetQQAvD_BwE
I hope this helps!
Andy
