Ground cable came off wildtrak went dead.
THE BEAST
Matt
Ford bronco 2022 wildtrak
Hi guys new on here. Took my new 2022 wildtrak out for the first time today in az
The beast came to a dead stop. Open the hood. Ground cable was off. Thinking ok easy fix. Well got that all tighten up.
Now the 4x4 won't work and check engine light is on. Soooo I have to take to dealer on Tuesday super sad day.
da_jokker
Jeep Wrangler JKUR
Many Have found that disconnecting the battery for 20 mins helps the Bronco Reset
THE BEAST
THE BEAST
Matt
Thank you! I will try that first
da_jokker
Jeep Wrangler JKUR
Good luck. The Bronco is very finicky when it comes to electronics and I'm sure you're loose battery cable didn't just go from power to non-powered, but probably bounced around a little bit and did some "surges". Could have easily thrown all the electronics for a loop.
THE BEAST
THE BEAST
Matt
I know I am not filling good about it at all
But I am coverd on warranty so that's good. I just got it 2 weeks ago😞 and driver side window is not dropping when you open door. But the rest are. Thanks for the feed back.
da_jokker
Jeep Wrangler JKUR
Did you try the window calibration? I haven't read a lot on it, but it seems that during the calibration fixes a lot of the window issues.
THE BEAST
THE BEAST
Matt
Just dropped it off at the dealer. They need to take care of the problem. Thanks for the feed back. We have went through a lot to have this rig they need to fix it 😆
