Exterior Keypads Programming Question
justinnx
Nebraska
Hello new Bronco owner here and did not get the card that shows the factory key code for the keyless entry. Do I have to go to a dealer to get this programmed? I cant seem to figure this out and would appreciate any of your insight.
Bmancpa
1989 Cadillac Allante, 2015 Mercedes C400
Salesman gave it to use with the keys. Did you check the glovebox? I’d call your salesman if not there.
justinnx
justinnx
Nebraska
I am the 2nd owner. Dont know the original salesman. How else can i figure this out?
Bled656
Daniel
Phoenix Az
2018 f150 ecoboost
I think you can check the number in your screen, haven’t played woth it yet so i’m not 100%sure
Bmancpa
Our salesman said the dealership will always have it. Do you know what dealership?
Bmancpa
Someone on here may know a better answer, but in the meantime I would contact your local dealership and ask.
ProdigyJKU
Rob
2012 Wrangler
Mine was on an instruction sheet in the glove box.
I would take a pic, but I don't feel like shoveling the snow right now.
grayshadow
Charles
Humble, Texas
Mine was in the plastic envelope with all other paper material in the glovebox.
Scott R Nelson
Meridian, ID
Thanks for the links.
The first thing I plan to do when my Bronco shows up (hopefully in a couple of weeks) is program a new code to match the one I use on my Escape. I like to use a different code than the default so that if someone ever "steals" it I can easily change it. Plus it's nice if both cars have the same one.
Scott R Nelson
Meridian, ID
Make that four weeks. I didn't find the keypad programming information in the Bronco owner's manual, but I looked it up for my Escape. Programming the Bronco keypad works exactly the same as for the Escape, which also matches the link above for how to program a new code.
I managed to successfully program in a new code that matches the other car, so I'm all set with that.
