Door Sill Protectors
mblur05
Los Angeles
2022 Bronco BlkDia. Sasquatch
Hey Everyone, I installed these door sill protectors and so far for a month they seem to be holding up great. The doors will need to be slightly slammed to close properly at first but thats due to the rubber door seals having to form to them. This was the case for my Bronco since I just got it back in December. Other than that they work well and I like the tread on them.
Its tricky to get them lined up at first but just use some painters tape to mark the location and peel the backing off, then press them down. I walked on mine using my body weight to help.
Check out my Amazon Affiliate link below.
https://amzn.to/3XROgl4
Ford Bronco Door Sill Protectors 1675093840905
Installed=
Ford Bronco Door Sill Protectors 1675100715976
WheresMyBronco
Los Angeles
2023 Badlands
No pictures of the actual product installed on your car? Also isn't that an Amazon affiliate link?
mblur05
mblur05
Los Angeles
Sorry I forgot to add the photo -here it is and I will add it to my OP.
Yes that is my Amazon affiliate link, just trying to make some extra $$ to help pay for the Bronco. I was thinking of doing a Youtube channel maybe. These days you gotta have something extra coming in.
Ford Bronco Door Sill Protectors 1675100238734
WheresMyBronco
Los Angeles
2023 Badlands
Just a heads up, from what I've seen I think you just need to be sure to disclose that it's an affiliate link or else Amazon/this forum might shut it down or kick you out of the program, which is why I was wondering
mblur05
mblur05
Los Angeles
I didn't see anything stating otherwise in the rules but I changed it noting that its an affiliate link.
