Constant chime
MikeyFrog
Iowa
Did something change? My bronco keeps doodledooing me when I turn it off, like if you left the lights on, but I can't figure out what is causing it! Help? I'm losing my mind
Hmm. Are you certain you didn’t leave the lights on? It’s easy to hit that switch with your knee and sometimes the bronco gets confused and you just have to rotate the switch a bit to let it know you still care. I know that sounds dumb but it’s common:
https://www.bronco6g.com/forum/thre...-doors-off-after-shutting-off-ignition.47550/
Could also possibly be the rear seat reminder thing?
GABroncin
Georgia
www.instagram.com
Jaguar E-Pace, Bronco Badlands
Check for the rear passenger alert. Might be buried in the settings. Mine does it without the visual on the screen sometimes.
TrailRaider
Mr. G
So. Cal
Focus ST, Mitsubishi Montero, Bronco Badlands
4 door? Weight in the back seat?
MikeyFrog
MikeyFrog
Iowa
It stopped now. Did it at Menards. At home. I was confused. Sometimes this car has a gremlin, the windows, radio issues...
