Center console vault ?
Blksn955.o
Greg
Wentzville, MO
17 Ford Escape Ti, 94 Ford Mustang GT, 21 BL
No argument here. I've been carrying for 35 years and I firmly believe you should never leave one in a vehicle anyways. Even with a vault it's only encased in plastic so a good smack with a hammer will tear it right apart. Take the vault and stick it in a vise and crowbar it open. But you're talking to someone who has an 1150 lb safe in his bedroom. ?
This ^
Side note...even those car vaults do not need much to get inside. Father-in-law lost the keys to his and took me 30 seconds to get into it with maybe a scuff mark and no tools used. learned a trick from an older retired officer.
Zeke013
Oregon
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
He is another option if you have more stuff than will fit in your center console. :)
Please stop spamming this site with garbage posts...
...that safe and trailer is very likely going to exceed the Bronco's published tow rating.
ne2000
Nathan
St. Louis
www.instagram.com
Bronco, Mustang GT
4avor8ntfair
Houston, TX
BL-non SAS, 2.3 auto
I just installed the center console safe. Pretty simple to install and change the passcode.
Ford Bronco Center console vault ? 097BB4EA-09BC-4B80-A7B6-82C47B9367B7
Ford Bronco Center console vault ? 733CA7DD-7918-4880-B2D1-CF0D3B9B899F
Ford Bronco Center console vault ? 7C1F6668-90F6-4BAB-80CF-BF9D2244A9BB
sage729
Ian
Maryland
4dr Big Bend soft top, Area 51, non SAS, mid pack
What were you able to fit inside? I'm still debating on getting one or the rear cargo area vault. Thanks.
4avor8ntfair
Houston, TX
Holstered p365xl fits if you maneuver it. There’s a bit of room for a sunglasses case and other small stuff. It’s not very bit to begin with.
mangelo
San Francisco
2021 Badsquatch LUX Softtop 4 Door Carbonized Gray
Does this lock box still allow access to FOB key FOB programming at the bottom of the center console etc? If I remember, FOB pairing etc happens by putting key FOB in center console after removing the bottom lining. Thanks in advance for feedback on this!
bronc'o
JC
CT
2021 JT Rubicon, 2020 Defender FE, 2022 Bronco WT
There is a lock but with the doors off and the wire pass through directly below the lock, it would be better with the vault. I feel the vault bolted inside the console vs a lock with access for a screw driver or other tool to break the armrest would be more secure.
I installed the vault in my Wildtrak. It is heavy duty, and ideal if you go to the beach, etc, and want to leave your wallet, cc, etc, behind.
Ts3794
Ron
Reno
Jeep
What secures the vault against removal.
Instruction look like side screws are used.
bad guy might just want to remove, and open later..
I want to get this, but, I want it secure..
thx
