- Jul 9, 2020
- 31
- 1,758
- 4,171
- Pittsburgh
- 2018 Honda Pilot
- Badlands
1. Beadlock is not required for most of us.There's a lot wrong with this...
-Tires are a wear component. You're going to replace them eventually.
-The bead-lock capable wheels are just that, capable. You still have to buy separate bead lock rings from Ford for them to actually be bead-lock wheels. You're going to have to shell out another $400 plus install just to have a true bead lock wheel.
-Aftermarket modifications do not void warranties. I wish that this shit would stay off forums. It's one of the biggest myths in car culture, right up there with fuel pumps needing to be submerged in the tank to stay cool.
-You can buy a set of true bead lock wheels and 35's for less than $2500 if you truly want a set to thrash around. That way you can have a trail set and a street set for *less*money and not get bummed out if you scratch a wheel. If you're just doing it for the aesthetics, there's nothing wrong with running 35's on 17x8 wheels for street duty.
2. Aftermarket upgrades can void your warranty if the dealership can prove that it caused the failure. You will probably be okay with this type of simple upgrade, but there is a lot of gray area here that I will be avoiding. You do you.
3. You are not accounting for the cost to regear and probably add some additional lift. Add in all of the labor if you're not doing the work yourself and I'm sure you will be well above $2500.
