BD rims with SAS tires?
Quest
Massachusetts
2023 Ford Bronco Black Diamond 4DR
It looks like the BD stock rim is 17x7.5 and Sasquatch is 17x8.5. The stock Sasquatch tires are Goodyear territory M/T. Specs indicate that the Sasquatch tire is 8-11" rim size. Assuming my numbers are correct, this would mean the stock BD rims will not work with the stock Sasquatch tires, is that correct?
Lowcountry Bronco
William
South Carolina Lowcountry
Usually it's listed as recommended wheel size but yes, 35's will fit on the stock BD wheels. Plenty of threads with pics and insight for you ..
https://www.bronco6g.com/forum/threads/35s-on-stock-black-diamond-wheels.60456/
https://www.bronco6g.com/forum/threads/35x11-50r17-on-black-diamond-wheels.65974/#post-1800745
https://www.bronco6g.com/forum/threads/steelies-with-35s-anyone.67375/
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
The Black Diamond wheels are indeed too narrow for the factory Sasquatch tires. I guess they will technically mount, but it's not within Goodyear's recommended rim width, so it's a bad idea.
But there are 35 sizes that will fit on 7.5" rims. Common sizes:
  • 35x11.5R17 - ie. Toyo Open Country
  • 35x10.5R17 - ie. Kenda Klever
  • 255/85R17 - ie. Micky Thompson Baja Boss
Those all have (roughly) the same diameter as the Sasquatch tires, but are narrower in width.
Pressurized
Rod
Gilbert, AZ
Gen 6 Bronco - Jeep JKU - Wrangler LJ (sold)
Right on! The 285/75R17 is right there also. All around 34.5 and fit on a 7.5" wide wheel.
