Archaic Raptor Headlights installed
23BDBigSean
Sean
Atlanta, GA
2023 Bronco
Do you know if this wire is hooked up? I’m almost positive this is the wire that connects to the battery for the accessory power of the lights to do the “breathing start up animation”
Ford Bronco Archaic Raptor Headlights installed IMG_4623
Bmason401
Exton, PA
2024 Ford Bronco 4DR
Hey Sean,
They did not hook up that one. They told me they believed that was only needed to be hooked up IF I wanted the white halos. I went with the Amber halos.
Do you know if that has to be done? if so, does that mean I have to go back and have them take off the entire grill cover, headlights, etc to get to that?
Also, do you know what # that should be plugged into on the fuse box if I do need to do that?
23BDBigSean
Sean
Atlanta, GA
2023 Bronco
Sorry I don’t have that info. I’ve been looking at these lights for some time- but don’t have any actual hands on installing these. It’s my understanding that ACC wire is for connecting the startup sequence when the vehicle is off. The two of the three other wires pictures are for the white/amber halos. I would imagine that ACC wire connects into an available space in the battery that can supply that number of amps for the ACC wire?
