ARB Bronco Under Vehicle Protection Kit
Caleb@PandaMotorworks
Caleb
St Louis MO
Give protection to your Bronco's vital underbody components including steering, engine sump, transmission and transfer case with the ARB Under Vehicle Protection panels! Laser-cut, press formed and folded 3mm sheet steel is used in ARB UVP to provide superior strength!
The ARB UVP to suit the Ford Bronco consist of four carefully designed panels. The front sump, transmission, and transfer case panels bolt directly to the chassis to provide continuous under-vehicle protection from the front bumper to the rear of the transfer case. Each UVP panel includes a return edge to add strength to the 3mm panel.
To retain the strength and protection required of an ARB UVP, full vehicle servicing will require the removal and refit of panels to obtain access to drain plugs and other service points. This provides an opportunity to check for damage and buildup of dirt and foreign matter. Provision is provided to drain engine oil only with a removable insert in the second panel.
ARB's UVP will fit with or without an ARB front bumper. Fitment has not been confirmed with other bumper designs.
We have 2 of these kits in stock here at Panda Motorworks ready to be shipped out, with more on order set to come in soon! Link Below!
Ford Bronco ARB Bronco Under Vehicle Protection Kit 5480100_v1
Ford Bronco ARB Bronco Under Vehicle Protection Kit 5480100_v4
Ford Bronco ARB Bronco Under Vehicle Protection Kit 5480100_v5
Ford Bronco ARB Bronco Under Vehicle Protection Kit 5480100_v6
Ford Bronco ARB Bronco Under Vehicle Protection Kit 5480100_v7
Ford Bronco ARB Bronco Under Vehicle Protection Kit 5480100_v9
Ford Bronco ARB Bronco Under Vehicle Protection Kit arb-5480100_zb_xl
Aman
Aman
Northern NJ
2-door options available?
broadicustomworks
Hanging Rock, North Carolina
Less cost than I expected.
Will be looking out for the videos/comprehensive underside pics to see how this fits up and what it covers.
Caleb
St Louis MO
Coming soon! We will keep this thread updated.
Caleb
St Louis MO
Unsure if this kit will fit a 2 door. ARB's website doesn't say anything about it fitting or not fitting the 2 doors. Looking in to it.
