Android One UI 6.0 update broke Android Auto, random disconnect
Pure_energy1
Vince
Montréal, Canada
Bronco wildtrak
Seems to be a known issue on Android forums among all manufacturers.
The One UI 6.0 update on my Samsung s23 ultra seems to have broken Android Auto causing random disconnects.
Trying my luck here, has anyone found a solution, or will we need to wait for an update to resolve the issue?
Thanks,
DRC
Cedarpines Park, CA
22 Bronco
Thanks,
I am also experiencing the same issue.
One UI 6.0 update on my Samsung s23 ultra with random disconnects since 6.0.
I have also been using DailyRoads Voyager Pro since 6.0 and thought that that may be causing the random disconnects.
I had experienced an occasional disconnect prior to 6.0 but now it happens on a daily basis.
Have always connected wirelessly to Android Auto.
I have no solution either.
OnlyOnce
Ken
Pa
2023 Bronco
I have had similar issues even when I had my 2500 Silverado! It would be nice to know if thier is a fix but as far as I can tell thier has not been any updatres that have recified it, only made it worse
Balt
Bradley
Houston
2023 Bronco Badlands SAS / 2017 Lincoln Nautilus
I'm having major issues with my Android auto (wireless) constantly disconnecting, sometimes after only a few seconds of reconnecting. The most annoying thing about the disconnect is it will not let you reconnect unless you're at a complete stop, really wish I knew how to turn that off with forscan. Has there been any information put out on a possible fix?
