Adjusting seat tilt with hardware?
cbol
Candler
Georgia
2023 Ford Bronco
I'm curious to know if anyone has added hardware to provide tilt to the bottom of their seat. This is common with electric powered seats so you can tilt it back or forward to provide support under your legs. I'm a decently tall guy being 6'3, so I ride with my seat all the way back, and if I could provide more support under my legs it would make road trips much more comfortable..
I'm considering removing the bolts that connect my seat to the floor and adding a handful of washers, but wanted to see if anyone has found a better solution.
Thanks,
Candler
Murfman
Colorado Springs
2021 WildTrak, Cyber Orange soft top
Justin B. McBride, on youtube is a big guy and he did a segment on seat shims made out of machined aluminum.
Bruzer22
CO
1968 Mustang, 2022 Bronco
Mlarv
TN
2023 Bronco/ 2022 F150/ 1968 Mustang
Use an old hockey puck as a spacer. I used one on my FJ
cbol
cbol
Candler
Georgia
2023 Ford Bronco
Thanks,
Candler
Thanks,
Candler
After looking at the $80 Desert Does It hardware for sale I figured this fix could be solved for much less. I got 3/8-1 1/2 washers from the hardware store and put them under my front seat mounts. I added 6 (0.5-0.7 inches)under each mount, but I’d say you could probably add up to about 12 washers if you really wanted. Using the stock bolts, there were about 5 full rotations on top of each Mount after I put the washers in.
Obiwan
Southwest
Don't care to share personal info
The price of those DDI basic as it gets metal plates with two holes drilled in them is flat out laughable. You can make these yourself with some metal plate, even if you needed to stack it to obtain thickness in about 20 minutes.
How long is the guide pin on the bottom of the seat bracket?
Bohlmbo
Bob
St. Louis
2021 Bronco, 1966 Mustang, 2014 Jeep Wrangler
They make adjustment spacers for Jeep JK rear seats that I used on my JK driver seat.
JK rear seat recline kit
