A/C blend motor malfunction 2021 first edition
Tfmorrell
Mignonne
Evolution#8
2021 first edition
2021 first edition. The blend motor(s) are malfunctioning causing hot air to come out on the passenger vents, and hot/cool air to come out the driver side vents. Called the local dealerships to make a service appointment and was told August was the earliest! So question I have is does any one know if there is a blend motor reset procedure for the bronco? like the procedure for the f150 when a new blend motor is installed? Did a search and found nothing. Also has anyone had this problem and had it fixed at the dealership, and have the parts list?
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there. Can you send us a DM with your VIN and dealership info? I can look into this for you.
DrBriGuy
2021 Ford Bronco Badlands
Just started having this problem this evening. Bummer. Any luck resolving?
