malpais
Some old Honda
Looks like the fit is good. He says in the video the factory washout floor “is garbage” but lists no actual complaints. I wonder what issues there are with it and how this product is superior to the factory vinyl flooring.
Armorlite_Kail
Kail
Austin, TX
23 Bronco 4dr WT, 18 JLU Wrangler, 18 JKU Wrangler
We love Ken, as a shop owner he really emphasized having a shop do this install.
I did the test installs and would say if you can lift the front seats out, it’s as easy or easier than a Wrangler JLU install.
Having some experience removing interior trim would be a plus, but if you follow instructions and don’t force it together without checking the alignment of the clips, you will be fine.
If any of that deters you, All Pro in Michigan or one of our many other dealers would surely get you setup.
MtnTopComms
Brandon
Klamath County Oregon
2012 Audi Q5
Unfortunately you don't have installers in the Pacific Northwest so some of us would have little option but to attempt ourselves.
Eroc88
Ohio
Jeep
I have the factory vinyl flooring and I have zero complains. He just saying that to sell a product. Only problem I see with this product is if water so happens to get under the flooring, the backing material will hold moisture.
malpais
Some old Honda
Not 100% sure but I think the factory washout floor also has some type of fiber backing material as well.
Eroc88
Ohio
Jeep
At the 9min mark shows what's under the factory flooring.
Bmurraybronco
Brent
Branco 4door
I hope those plugs clip in tight. I’ve hit mud puddles around 30mph and it will pop the factory plug on the passenger side out and shoot mud into the cabin haha. The factory ones even twist and lock.
MichaelCar001
UK
BMW
Came across a video on the new Armorlite flooring (@Armorlite_Kail).
Close-up look and install. Looks nice.
Looks pretty good. And it seems like it is done easily. But I know myself. It's hard for me to repeat something from the video tutorials.
Armorlite_Kail
Kail
Austin, TX
The insulation we use on Armorlite floors is a polyester fiber, not a cotton. Poly fiber does not absorb moisture like a natural fiber. It is just plastic. The stock floors are foam.
The difference is ours allows better flow to the passive drains, these are separate from the exposed drain plugs on the floors "A" surface, the passive drains are located throughout the sheet metal floor (all models) and are a one way passage for water to escape. With the OEM foam and film pressed against the sheet metal there is less breathing or ability for water to travel down to these.
We chose this carefully during the construction of our floor and feel it is a better option.
Ford Bronco Armorlite Flooring for the Bronco - installed video IMG_2636.JPEG
Armorlite_Kail
Kail
Austin, TX
Our plug will stay in place for this scenario, The plug snaps into the metal floor easy but is surprisingly difficult to remove, and the lid if close properly should stay closed even during submersion.
I have extensively tested our Wrangler plugs and although I haven't had as much field testing with the Bronco plug we feel this is an improvement.
Plus the last plug I installed, I gave it a tug and said "that ain't going nowhere", so you have that.
Mario3241
Mario
Las Vegas
Ford Focus
I’ve been eyeing the vinyl OEM Ford Floor replacement. Is there a 6G forum promo code by any chance?
Armorlite_Kail
Kail
Austin, TX
Right now the presale is no code required 10% off.
I know I am selling you an alternative, but I reviewed the washout floor to see if we had a business case to compete against the factory option. Mind you we are owned by Auria Solutions, we make oem floors as 99% of our business, we don't have this specific model but we do a lot of Ford passenger and commercial work, always at their guidelines and price point. Aftermarket division, we can do whatever we want and not worry about a super low piece price dictating the quality or performance.
The factory floor is lighter duty to what we offer in Armorlite, I didn't like the white waxy residue that was creeping out in low traffic sections, I have seen some floors cut and tear and handling it can see why. That and the plugs seemed to have some problems. All of this and a list other minor issues, we found enough room for improvement to invest in very expensive tools and compete.
EGSquatched
Matt
Central Ohio
23 2dr Base Squatch
How is the noise level compared to factory washout floor and carpet? I’ve had both and while I would prefer the washout ability I appreciate the quieter cabin with the carpet.
