X-Rack
Nick
Bethpage, NY
2022 Ford Bronco
Fishing season is gearing up, carry your rods safely and in style.
X-Rack Trail Sight Mount Fishing Rod Holder for the new Ford Bronco, designed to seamlessly attach to the stock trail sights on your front fenders. You have the option to mount a single rod holder on each side or double rods per side. Built with robust all-aluminum construction, our rod holders are not only durable but also rust-free. What sets them apart is the inclusion of our exclusive rod locking bar. Once your rod is mounted, simply swing down the lock bar and secure your rods with a padlock to minimize the risk of ā€œsmash and grabā€ theft. Feel confident stepping away for a quick coffee break, knowing your rods will be right where you left them.
The best part? Even with double rods mounted on each side, you’ll still have easy access to your hood. We understand the importance of accessing the battery for tire compressor power to air back up on the beach, so we ensured there’s no need for disassembly.
Available with White or Black Inserts (White powder coated rod holders available on request)
Rod holders are designed for spinning reels to use locking feature and can accommodate large reels without touching the vehicle.
Rod butt maximum dimension:
With PVC Insert: 36mm/1.417 inches
With PVC Insert Removed: 42.5mm/1.673 inches
Use code B6G10 for forum discount
Ford Bronco Fender Mount Locking Fishing Rod Holders (single or double) IMG_7089
Ford Bronco Fender Mount Locking Fishing Rod Holders (single or double) image7 (1) copy reduced
Ford Bronco Fender Mount Locking Fishing Rod Holders (single or double) IMG_1575 copy
Ford Bronco Fender Mount Locking Fishing Rod Holders (single or double) 2023-09-17 10.02.01
Ford Bronco Fender Mount Locking Fishing Rod Holders (single or double) IMG_1296
Ford Bronco Fender Mount Locking Fishing Rod Holders (single or double) IMG_5788
JawnyBronco
DelMarPa
2023 Bronco 4dr
Whose DE AGM Heritage Edition is that??? šŸ˜
