Ninjak
Miami
That's kind of the point of a spare tire.... I'm not sure why the owner couldn't have just driven out themselves.
Most likely did not have a jack to handle the change, or the tools? The Jack that comes with our Bronco's are stressed on a concrete flat surface, let alone sand.
ScLeCo
Springfield
Charger Hellcat
A good lesson to always test your equipment in the conditions in which they will be used BEFORE you actually need it.
3People1Body
Christopher
West Virginia
Wildtrak, F150 and Taurus.
I think they went to be checked out? They didn't need the spare, just needed air.
That poor bronco... The headlights had a sad look to them going up on the rollback, as opposed to the angry Jeep look. It needs some love.
Greymatter18
Phoenix, Az
Badlands Sasquatch
Is anyone able to identify his front bumper?
ROCKO
San dimas
Was it abandoned and left for recovery?
Jr87mustang
Josh
Northern Cali
Huh, I expected this to be that BroncBuster guy at it again.
Patrickgault
Patrick Gault
South Carolina, USA
Ford Bronco, 2022 Outer Banks.
Sucks to see forsure. At least it has thinking about a spare gas can mount. Any recommendations for a good mount?
woodysfj40
woody
SW Utah
www.instagram.com
BJ74, FZJ80, NCV3, JHF
Sand Hollow is tough on vehicles :)
Headsong
That's totalled.
See ya 50k, probably won't get insurance.
MadMan4BamaNATL
Ray
Atlanta
So weird that the owner wouldn’t even try to crank, even more if they didn’t have a compressor out there on that trail.
Recoveries are so expensive that being able to drive at least to the trailhead for a simple tow would save hundreds.
Also not sure why anyone thinks this is totaled. If mostly cosmetic and some suspension parts, may not be so bad; would take a while, but that Bronco may be saved.
PSA, be extra careful (slow) on shelf roads or going up or coming down a tiered rock wall. Spotters are highly recommended when things may get tippy and if you’re on a tippy line, back up and slide over a bit.
woodysfj40
woody
SW Utah
www.instagram.com
In many cases, blown airbags = totalled. Cost comes into play too. Looks like most of the sheetmetal is damaged.
I agree on the spotter, sadly most of them aren't any more skilled than the drivers. I cannot count the number of times I've witnessed disasters WITH a spotter. I gave up on using a spotter years ago...like, 15 years ago :)
