6x139.7mm Bolt Pattern Method 312 17x8.5" Wheel (0mm Offset)
Status
Not open for further replies.
Stage 3 Motorsports
Joel
www.stage3motorsports.com
2021 Bronco Badlands 4 Door 2.7L Ecoboost
Available in Matte Black or Bronze
If you are in the market message me for forum pricing.
Frank
6x139.7mm Bolt Pattern Method 312 17x8.5" Wheel - Matte Black (0mm Offset)
Ford Bronco 6x139.7mm Bolt Pattern Method 312 17x8.5" Wheel (0mm Offset) 1635881351947-png
6x139.7mm Bolt Pattern Method 312 17x8.5" Wheel - Bronze (0mm Offset) MR31278560900
Ford Bronco 6x139.7mm Bolt Pattern Method 312 17x8.5" Wheel (0mm Offset) 1635881302266-png
Highlights:
  • A356 Aluminum w/ T6 Heat Treatment
  • Street-Loc V.3 Lip w/ Undercut
  • Standard 6x139.7mm Bolt Pattern
  • Features 0mm Offset
  • Sold Individually
Street-Loc V.3 Lip & Six-Spoke Wheel
When looking for an off-road wheel, a beadlock variant is a nice option to conquer the trail. Method's 312 six-spoked wheels come in a matte black finish that gives your truck an aggressive and rugged off-road look, but can function as a street legal wheel as well. Its Street-Loc V.3 Lip with an undercut mimics a true beadlock wheel. With a six windowed point design and debossed Method logos, you'll be the envy of everyone you encounter.. You can trust the 312 wheel to get your midsize truck where it needs to go, on or off the beaten path! High-Quality Construction for Maximum Durability
Method's 312 wheel fits right onto your truck's hub and is built from high-quality components for longterm durability. This 17" diameter wheel is manufactured using A356 aluminum with T6 heat treatment so that it is strong and durable enough for practically any application but lighter than your original factory stock wheels. Each wheel comes with a standard 6x139.7mm bolt pattern that allows them to fit right on to your truck's hubs without the use of wobble bolts, spacers, or other adapters. These wheels include a 4.75 backspacing and a 0mm offset to provide a great look and the ability to use aggressive suspension upgrades without clearance issues.
Wheel Specs:
  • Size: 17x8.5"
  • Bolt Pattern: 6x139.7mm
  • Backspace: 4.75"
  • Offset: 0mm
  • Load Capacity: 2650lbs
  • Hub: 106.25mm
Fitment:
  • 2019-2021 Ford Ranger Ranger w/ 6x139.7mm bolt pattern
  • 2021 Ford Bronco 2-Door & 4-Door with 6x139.7mm bold pattern
  • 2010-2021 Toyota 4Runner 6 lug w/ 6x139.7mm bolt pattern
  • 2005-2021 Toyota Tacoma 6 lug w/ 6x139.7mm bolt pattern
  • Will not fit Bronco Sports
Tires Sold Separately: This Method wheel is sold individually and a quantity of four will be required for a complete installation.
Note on product image: The wheel seen in the picture above is not precisely representative of all size configurations.
dweskamp
Dan
Missouri
2016 GMC truck
How about some Black Rhino Cino, bronze?
Exomodo
Ryan
Marquette, MI
Ranger
Where are these made?
Stage 3 Motorsports
Stage 3 Motorsports
Joel
Message sent.
Unfortunately as with most wheels these days
"Method is an American company. Their wheels are designed, engineered and tested in the USA. They are, however, manufactured in China."
Stage 3 Motorsports
Stage 3 Motorsports
Joel
Method wheels are 15% off through Dec 6th, get them while they are on holiday special!
Status
