Mitch Panda Motorworks
Mitch
St. Louis, MO
www.pandamotorworks.com
2021 Ford Bronco, 2014 Fiesta ST
When it comes to diagnosing a problem within a vehicle, the first thing most people will do is use an OBD2 scanner to scan for trouble codes. These codes are generated by the vehicles ECU and can provide valuable diagnostic information. This method of vehicle diagnostics has been the standard since the Mid-90s when it was mandated that all new cars manufactured in the the US come equipped with OBD2. For us car enthusiasts this not only gave us an easy way to diagnose our vehicles, but it also gave us a way into our Vehicles ECU.
With the adoption of OBD2, custom ECU tuning to bolster vehicle performance followed shortly after. Along with that came other non-performance modifications to tweak how your vehicle operates, and that's what we are here to talk about! Introducing PandaScan, our very own ECU Reconfiguration service! Using the power of FORScan and provided PandaScan device, we can remotely access your Ford vehicle's ECU to unlock hidden features and more for a set fee. For example, on a 2021+ Ford Bronco we can unlock all the G.O.A.T. Modes, Recalibrate your speedometer to account for bigger tires, and activate Bambi mode, which allows you to keep your fog lights on when high beams are activated for maximum light output. These are amongst the many features we can bring you with our PandaScan Service.
Possible Calibrations Include:
-Deactivating Autostart/stop
-Enabling Bambi Mode (Fog Lights Remain on when High Beams are switched on)
-Adding ALL G.O.A.T. Modes
-Eliminate Double Honk
-Tire size Recalibration
-Enable OEM Fog Light Switch
-TPMS Disabled
-& More!
Ford Bronco Introducing PandaScan, Our Remote FORScan Service! PandaScan_480x480
Once you've decided to purchase the PandaScan service and a Panda Motorworks approved PandaScan device, you will need to schedule a session with our calibration team to complete the service. If you do not have an ELM327 Connector, you can purchase one here! You need to make sure you are able to receive a solid internet connection on your computer from your vehicle, as you will be need to be in or near your vehicle to complete the process. You will need to have the latest version of FORScan installed so we can access your vehicles ECU. You can find and download the FORScan program here. You will begin the process by opening TeamViewer at the scheduled time, if you need to download TeamViewer click here. The calibration specialist will then call you to give further instruction, so please have your phone ready. Once connected with a member of the calibration team you will then connect the OBD2 Scan device to your vehicles OBD2 port located in the drivers footwell. Once you have a connection, make sure the device's switch is in the "HS" position and then plug the other end into your computer. Once the connection is established, you are ready to begin the calibration process.
Ford Bronco Introducing PandaScan, Our Remote FORScan Service! switchgif_480x480
You will begin the process by putting your vehicle in the "Key On" or "accessory power" position. This will allow our calibration specialist to access your vehicles ECU and allow him to make the changes requested. You will need to remain on the phone with the calibration specialist as he will need you to occasionally flip the switch on the OBD2 module from the "HS" setting to the "MS" setting and vice versa. This process can vary in time depending on the services requested, but within minutes the calibrations will be safely applied to your vehicle! Upon completion, you can disconnect the OBD2 module and enjoy your new unlocked features.
Ford Bronco Introducing PandaScan, Our Remote FORScan Service! IMG_0403_480x480
We are proud to offer this service and help you get the most out of your new Ford Vehicle. This task can be daunting when done alone and can have some serious negative effects, so trust the experts at Panda Motorworks to take care of your vehicle and get it done right the first time!
Pricing for a PandaScan Service Session is as follows:
3 Calibrations for $55
Additional calibrations can be added for a small fee.
4 Total Calibrations for $65
5 Total Calibrations for $70
or
6 Total Calibrations for $75
Panda Motorworks Approved ELM327 Connectors can be purchased for $25 if needed.
After purchasing PandaScan, an appointment must be made with our calibrator to perform the service. Appointments are available at various times throughout the week during our business hours of 9am-5pm CST Monday - Friday!​
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
Any intention of listing a "menu" of options so we know how many adjustments we need to buy for? I can think of two I want, but have no idea the other possibilities.
Rjacks258
Randy
Punta Gorda, FL
2022 Ford Bronco, 2019 Ford F250, 2009 Ford Ranger
Hmmm, very interesting.
j_marinelli
Spring Branch, TX.
I was curious as well so I dug around their site.
From their site:
https://www.pandamotorworks.com/products/pandascan-remote-obd2-configuration-service-21-ford-bronco
Changes We Can Make Include:
-TPMS Disabled
-& More!
Mitch
St. Louis, MO
Made an edit to the original post! The possible calibrations include:
-TPMS Disabled
-& More!
Toccoa
Isuzu Rodeo Sport
You had me at Bambi mode!
Ford Bronco Introducing PandaScan, Our Remote FORScan Service! 1675200039065
HorizonHunter
Joseph
Chapel Hill, NC
-TPMS Disabled
-& More!
Appreciate that. I'd seen that list on your site and was mostly curious about "& More!"
Right now I'm on double honk and goat modes from that list. I'll need tire size eventually, way down the line.
Mitch
St. Louis, MO
FORScan has a wide range of uses, "& More" is all encompassing for special applications. For example if your Bronco has the Signature LED package and you install the Oracle Flush Mount Tail Lights, a FORScan calibration is needed for the tail lights to operate properly.
choppersean
Sean
Arvada, CO
'22 Badlands Sasquatch, 2-door, EG, 2.7, Auto
Do your modifications void the factory warranty?
Mo’ Money Mo’ Broncos
Bobby
Kansas City
Toyota Camry
What’s the timeline on “additional services”? ie. I get 4 configurations in February, and get 35’s put on in December, is it a whole new fee or still an additional service to recalibrate for 35’s?
BaseManSquatch
United States
Is it possible to totally eliminate the blinker noise or at least reduce it?
When turning on any Ford vehicle it makes that really annoying start up noise that even though is only a few seconds it feels like a minute. Is there any way to disable the start up chime?
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
This is all I can think of when I see this thread title….
Ford Bronco Introducing PandaScan, Our Remote FORScan Service! 769DFDC1-F9E9-48F5-84AE-02CC27EAD0C4
