Diabolical Inc
Lux Sponsor (Level 2)
shop.diabolicalinc.com
2020 Rubicon, 2021 Bronco Wildtrak
Stay tuned to our socials pages this week for launch news of the bronco slide drawer.
Access to your Bronco just got easier. Our Bronco all-aluminum tray and
mounting brackets made from 3/16 aluminum ship fully assembled and ready to install.
Cold rolled steel slides with 400LB load capacity (Extended) that lock in and out and still allow access to the storage underneath the tray with a quick connect rear panel. Slides have a lifetime guarantee from the manufacturer.
The Bronco 4 door slide floor requires no drilling or vehicle
modification. Simply remove the bolts for the D-Rings and bolt the Slide
Floor system into place using the existing holes and new supplied bolts.
There is a 2.5 inch gap between the Slide Floor and tailgate allowing you to add tailgate tables and other tailgate mounted accessories.
Slide Floor Dimensions:
Width: 41.5 Inches
Depth: 28.5 Inches
Height 2 inches
Slide Drawer (TOP)
The Slide Drawer is the perfect way to finish off our Slide Floor system. The Slide Drawer bolts to the existing Slide Floor giving you a drawer system that will also support gear on top. The aluminum drawer top is braced internally for additional weight capacity
The height of the drawer top is perfect for those who want a flat surface from the front seats to the tailgate for sleeping. The Slide
Drawer allows for 4,5, or 6 inches of usable space on the Slide drawer, perfect for tools, recovery gear etc.
Drawer Top Dimensions:
Width: 41.5 Inches
Depth: 28.5 Inches
Height 5.5 inches
Ford Bronco Bronco Cargo Slide Drawer / Slidefloor by Diabolical Inc 9450BD6E-70D7-41BB-82BE-CAE1D30E5242
Ford Bronco Bronco Cargo Slide Drawer / Slidefloor by Diabolical Inc BC8046CE-3D9A-44A5-ACFB-4F069B22B1D0
Ford Bronco Bronco Cargo Slide Drawer / Slidefloor by Diabolical Inc B6E89AFC-71F9-42C4-88BB-2CC85B421718
Katimari
Matt
Buffalo
2020 Toyota Tacoma TRD Off-Road Premium
Was just looking for something like this. Following for sure.
Lakelife36
Ben
Interior of BC
I'd love to use the slide drawer for a space to store my front row roof panels when they're off, but 6" of clear height and the drawer having a 2.5" gap to the tailgate both might be too tight. @Diabolical Inc do you have access to a hardtop to give this a test?
Ford Bronco Bronco Cargo Slide Drawer / Slidefloor by Diabolical Inc 20220808_070242
Diabolical Inc
Diabolical Inc
Ours is a soft top only at the moment. We might be able to test this with a local unit though.
Dusmw
Kansas
F250/Wrangler Rubicon
Would reinstalling the OEM tie downs impede slide operation? Photo of access to existing storage tray and jack storage area please?
weight of unit?
thanks looks like you solved what Tuffy couldnt figure out, flat floor height and full width!
Diabolical Inc
Diabolical Inc
weight of unit?
We pushed the install video to YouTube yesterday. This may help answer your questions.
are you asking if mounting the D rings to the drawer top would work?
it shouldn’t but you would have to drill your own holes and get the hardware.
overall weight is about 40 lbs (slides and reinforced ribs on the top are the bulk)
Diabolical Inc
Diabolical Inc
weight of unit?
here is the video for accessing the floor storage.
Dusmw
Kansas
Excellent this looks great wii watch for launch! thanks
Diabolical Inc
Diabolical Inc
@Diabolical Inc - what happened to the 2 door version promised in January!!
why doesn't anyone love us!!
It has taken us this long to perfect the 4 door, and we have one of those at our disposal.
ideally with the 2 Door locker and ridgeback (2 door seats removed) coming soon the slide floor/drawer isn’t far behind.
perfection takes time!
Mike777
San Antonio
Ford Bronco, GMC Terrain
Width: 41.5 Inches
Depth: 28.5 Inches
Height 2 inches
Slide Drawer (TOP)
Width: 41.5 Inches
Depth: 28.5 Inches
Height 5.5 inches
Great option, but does it come in black? Stainless steel doesn't really go with the interior.
Diabolical Inc
Diabolical Inc
Raw aluminum is shown for visibility, final product will be black powder coat like the rest of our Bronco products.
Dirty Bronco
Brad
Charleston
2021 Ford Bronco - 4 Door Badlands
Looks incredible! I had a few questions I was hoping you could answer.
1. what’s the load limit of the drawer cover? I believe what I read/watched said 400 lbs for the drawer itself. But what about the cover?
2. Will we be able to order the drawer cover at a later date if we just want the sliding floor for now? Or do we need to order it as a bundle.
3 price? I see the floor system is $1000
Diabolical Inc
Diabolical Inc
1. you should be able to do 500 + easy on the top distributed. Those ribs are beefy!
2. slide floor is one product with the drawer top as an accessory to the floor. You can use the slide floor by itself, but cannot use the drawer top without the slide floor.
3. We are estimating about $350 for the drawer top add on. Still waiting on volume pricing.
Dirty Bronco
Brad
Charleston
Thanks for the response. So just so I understand correctly, I can order the sliding floor now and order the drawer cover accessory at a later date for roughly $350?
