Status
Not open for further replies.
Ryan at ARB
Ryan
Auburn, HI
arbusa.com
Jeep LJ, Ford Ranger, Ford Bronco
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665445380563
Whether you’re a seasoned overlander or a newbie off-roader – we can all reap the benefits of an onboard air compressor. Its many capabilities include actuating Air Lockers, inflating tires after deflating, setting tire beads, drying off cookware at camp, pumping up inflatable paddle boards and kayaks, and blowing the sand off your boots and floor mats.
What’s even better? This invaluable adventure upgrade can easily be installed under the hood of your Ford Bronco with our new mounting bracket that has been validated by Ford engineers. Follow along for a step-by-step guide and pre-order your own by contacting any ARB or Ford dealer.
Requires:
ARB Twin Compressor Mounting Bracket #3580030 (Contact an ARB dealer to preorder)
ARB Twin Compressor #CKMTA12
ARB Manifold #171503
ARB Hose Coupling #0740112
Instructions:
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665445445140
1. Disconnect the negative battery terminal.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665445494923
2. Unplug the DLCM and remove the two M6 bolts holding the mount to the body.
DO NOT DROP.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665445522921
3. Remove and discard the harness plug and earthing harness.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665445560267
4. Remove fasteners (rear half only) for RHS inner guard and lower.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665445585231
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665445595510
5. Fit the rear support bracket (4655173) using the factory OE M8 flange bolt. Leave loose at this stage.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665445627108
6. Feed support tube weldment to the firewall and locate it onto the M6 stud. Once on, place the inner guard support bracket over the same OE factory stud, and fasten the OE M6 nut.
Torque: M6 – 7ft/lb
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665445679185
7. Use an M8 FL BOLT to temporarily brace the support tube to the rear support bracket.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665445698529
8. Fix the support arm to the firewall using the M10 Nut stick (bent profile shown below) and one M10 SEMS bolt.
Torque: M10 – 32ft/lbs
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665445797756
9. Once the support arm is fixed, remove the M8 bolt from step 6.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665445842350
10. Feed the U BOLT CHANNEL behind the chassis from the top
Note: the notch in the part faces toward the top.
11. Fasten the front support bracket to the U channel with two M10 FL bolts. Leave loose at this stage
12. Support Wiring harness to mount with a Zip Tie.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665445927458
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665445937404
13. Measure outside to outside of the two support brackets. They Should measure 220mm (8.6”). If not, adjust accordingly.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665445959669
14. Torque - M10 bolts to 32ft/lbs.
15. Torque OE M8 bolt from Step 4 to 16ft/lbs.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446017699
16. Remove Twin Compressor from the box and place it upside down on a soft surface.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446036171
17. Place the base plate onto the Compressor along with the DLCM.
18. Using two M6 x 25 bolts, two M6 Flat washers attach the DLCM to the Compressor.
19. Use one M6 x 25, one M6 Flat washer, and one M6 FL nut on the third position of the DLCM.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446068630
20. Use three fasteners supplied with the Compressor to complete the mounting, and torque to spec.
Torque: M6 – 7ft/lbs
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446093905
21. Secure the coolant hoses with two P clamps, M6x16mm bolts, washers, and flange nuts.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446114432
22. Using 2 x M6 x 16 bolts, washers, and flange nuts, fit the Compressor Manifold bracket to the rear mount.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446142824
23. Fit the Manifold feet to the manifold mounting bracket using M6x16 bolts, washers, and flange nuts.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446164646
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446173865
24. Temporarily remove the washer bottle filler neck by removing the bolts retaining them to the vehicle body.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446199322
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446207267
25. Carefully install the assembled Compressor, base plate, and DLCM onto the support brackets.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446230719
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446239621
26. Use 5 x M8 FL BOLTS to secure the base mounting plate to the Front and Rear support brackets.
Torque: M8 - 16ft/lbs
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446261025
27. Reinstall washer bottle filler neck 27. Plug in the DLCM by gaining access
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446277137
28. Plug in the DLCM by gaining access through the inner guard.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446297419
29. Reinstall the inner guard.
Note: Ensure to install the OE scrivet into ARB inner guard support bracket.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446326879
30. Using the fittings provided in kit 171503, fit 1 x JIC4 - 1/4 NPT fitting to the inboard manifold port (as shown in the image to the left).
Note: Ensure to use thread sealant on all 1/4 NPT threads.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446372515
31. Repeat the same process for the compressor outlet port.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446396500
32. Connect the manifold to the compressor using the braided hose and tighten.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446425090
33. Attach the hose coupling (0740112) to the outboard port on the manifold.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446453317
34. Using the wiring harness 180415, measure and cut 400mm of wire (purple/black) connected to the purple plug.
Note: Ensure the plug is retained (as shown above)
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446476938
35. Connect spade connectors to the cut ends.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446497352
36. Connect spade connectors to the switch as followed:
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446515972
37. Pickup power from the stability bar module fuse (10A) located in the engine bay fuse box. Fuse reference #158 in the owner’s manual.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446535469
38. Run wiring around the rear section of the engine bay to the compressor switch.
Note: Ensure to insulate the wiring in the conduit.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446560550
39. Connect spade connectors to switch pin 2.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446605405
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446616279
40. Crimp a terminal to the end of each of the two red wires on the compressor wiring harness (pn. 180414), and then connect to the positive battery terminal.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446644553
41. Connect the 2 black earth wires from the compressor wiring harness to the negative battery terminal.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446669933
42. Route the harness around the back of the engine bay. Cable tie every 400mm.
Ford Bronco How to DIY install an ARB Compressor in a Ford Bronco (+GIVEAWAY!) 1665446693265
43. Plug the two harnesses into the compressor connectors.
44. Cable tie the harness to the base plate.
Suits 2.3L & 2.7L Ford Broncos - Not compatible with Bronco Raptor and Everglades models
GIVEAWAY
If you made it this far, you’re in luck! We are giving away one new ARB compressor bracket to one of you lucky 6G members.
TO ENTER
1. Reply to this thread.
2. Follow/subscribe to at least one of our social channels.
Instagram: @arb4x4usa
Facebook: www.facebook.com/arbusa
YouTube: www.youtube.com/c/ARB4x4USA
The last day for entries is October 14, 2022, 11:59PST. The winner will be chosen randomly and will be notified in this thread
*ARB will never message you directly and ask for your credit card information*
Good luck!
mcinfantry
Lee
Louisiana
Badlands 2 door
Neat.
Grayeti
Greg
Illinois
21 4dr Badlands, 22 2dr badlands, & 23 Braptor
Looks like a nice option. Already following your Insta.
Razorback
Bill
Dallas
Lincoln MKX
I'm in. Been waiting for more options to choose from for mounting.
Deleted member 31057
Guest
GIVEAWAY
Count me in. I hope it'll fit a Bronco Raptor!
Stewkc
Stew
Kansas City MO
07 Trailblazer SS
What’s even better? This invaluable adventure upgrade can easily be installed under the hood of your Ford Bronco with our new mounting bracket! Follow along for a step-by-step guide.
Requires:
Instructions:
DO NOT DROP.
Torque: M6 – 7ft/lb
GIVEAWAY
TO ENTER
Good luck!
Very well done!
UtahBrandon
Brandon
www.puravidaoffroad.com
a number of classics and my 4dr Badlands
Requires:
Instructions:
DO NOT DROP.
Torque: M6 – 7ft/lb
GIVEAWAY
TO ENTER
Good luck!
I’m already following all of your channels as I was waiting for the compressor bracket release.
Turning Blue
Chuck
Northern Illinois
2019 F-150 Raptor, 2021 Mustang GT/CS
Enter to win a bracket? At least there's no fine print...lol. How about a group buy? Maybe then I'll try signing up for twit book face or whatever...lol.
Mario3241
Mario
Las Vegas
Ford Focus
Fingers crossed. Following you on Instagram. This looks great!
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
Pretty sure I already follow you on Instagram, but I'll make sure I do.
Status
