MandRautomotive
Mikhail
CA
If i am not mistaken this is the first light kit for the CAPABLE bumper. Manufacturing is starting Today and we should start shipping within the next 2 weeks.
  • Fits only metal CAPABLE bumpers
  • This kit includes the Driver and Passenger sides (1 order per Bronco)
  • Houses 2 square LED lights on each side. 4 total LED lights
  • White lights with amber DRL to match the rest of the Bronco accent lighting
  • Includes a metal shroud that is powder coated to give it a "built in look."
  • Includes all mounting hardware
  • No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware
  • Total kit has 160watts of power and is rated 16,000 lumens
  • If your Bronco comes with AUX switches you can add the DIY wiring harness kit your order for only $20. It will allow you to connect the lights together and extend them to your AUX switch area.
https://mandronline.com/collections...cts/2021-ford-bronco-capable-bumper-fog-light
Ford Bronco FORD BRONCO CAPABLE BUMPER FOG LIGHTS KIT 20220529_161639
Ford Bronco FORD BRONCO CAPABLE BUMPER FOG LIGHTS KIT 20220529_161646
Ford Bronco FORD BRONCO CAPABLE BUMPER FOG LIGHTS KIT 20220529_161602
Ford Bronco FORD BRONCO CAPABLE BUMPER FOG LIGHTS KIT 20220529_161614
Ford Bronco FORD BRONCO CAPABLE BUMPER FOG LIGHTS KIT 20220529_161540
Ford Bronco FORD BRONCO CAPABLE BUMPER FOG LIGHTS KIT 20220529_152456
Tarheel_Wes
Wesley
FJ
Question though:
Can you wire them to the existing fog light switch?
Ideally I’d like to wire the main beam to my factory fog switch and the DRL to an aux…
This doable?
MandRautomotive
MandRautomotive
Mikhail
CA
Question though:
This doable?
Have to check what factory wiring is capable of handling in terms of AMPS
sLopeFx
FxA
Los Angeles, CA
22 Bronco BD Sas, 07 BMW 335i, 02 Cooper S JCW
So, after a long 18 month wait for my Black Diamond Sas and multiple iterations to try to get it sooner, my order turned into a 2022, naturally. That also meant that I would be getting the capable bumper instead of the modular. I figured I would wait to see if the capable grew on me and it did, thankfully. The only issue was there didn’t seem to be ANYONE willing to make any aftermarket mods. Until now.
M&R Automotive has designed the perfect bolt on replacement for the subpar OE fog lights. The kit houses two large white LED lights with Amber DRL per side. That’s four massive lights making 16,000 lumens and they look awesome! The amber DRLs look exactly like the OE amber driving lights and mounted into existing locations without having to drill into anything. Install was simple at a few hours tops and the price was on point. This has completely changed the face of my BD beast and my auxiliary switches now have life...!
https://mandronline.com/products/2021-ford-bronco-capable-bumper-fog-light
A big thanks to Mike at M&R for thinking about all of us capable bumper owners who have likely been on the fence. I couldn’t be happier with the results.
Next is the 40” light bar that will be nestled in between the grill and the bumper. I’ll post some pix when installed and lit.
Happy Memorial Day everyone! 🇺🇸:cool:🇺🇸
Ford Bronco FORD BRONCO CAPABLE BUMPER FOG LIGHTS KIT FullSizeRender-14
Ford Bronco FORD BRONCO CAPABLE BUMPER FOG LIGHTS KIT CloseUp_Pass
Ford Bronco FORD BRONCO CAPABLE BUMPER FOG LIGHTS KIT FullSizeRender-9
Ford Bronco FORD BRONCO CAPABLE BUMPER FOG LIGHTS KIT CloseUpFront_Amber_Driv
Ford Bronco FORD BRONCO CAPABLE BUMPER FOG LIGHTS KIT FullSizeRender-7
Ford Bronco FORD BRONCO CAPABLE BUMPER FOG LIGHTS KIT FullSizeRender-17
Miggity02
SF Bay Area
Audi sq5 and VW GTI
Any plans for an amber option? And would you say these are a fog pattern or a combo beam? Is there a way to run 2 at a time rather than all 4? Great looking product as is, just wanting the amber option!
MandRautomotive
MandRautomotive
Mikhail
CA
The wiring harness we provide have 2 power wires (1 for white and 1 for amber) If you would like to split them in pairs, you can add 1 extra wire and would work perfect.
moborb
Jersey
996, Speed Triple, Odyssey, Civic Type R
1. Looks incredible!
2. Can I ask a real dumb question - how did you wire it all?
MandRautomotive
MandRautomotive
Mikhail
CA
You can purchase it with our $20 wiring harness to be able to tap them into AUX switches
Tarheel_Wes
Wesley
FJ
So, to clarify I can put the amber DRLs on a separate switch?
And yea, same question as above, is this a true fog pattern.
I’m almost ready to say “take my money”, if you made it optional to have one of the lights white and one yellow, That would seal it for me.
So, question is, do you make that square light also in yellow and not just white?
Tarheel_Wes
Wesley
FJ
OP:
Did you utilize an upfitter switch for this?
Most curious about how you power the DRL…whether by a separate aux switch or if they come on anytime your regular parking lights (or headlights) are on…?
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
Curious about your install. Got behind the bumper to swap some DD SS3 for the factory, and access is nowhere near as easy as standard bumper. Gave up and put them on my A-Pillars. Excited if it's as easy as you make it seem. And is yellow light an option for true fog?
Tarheel_Wes
Wesley
FJ
One more question:
What are the dimensions of the actual lights?
3” x 3”? Smaller?
