JTopsUSA
www.broncosunshades.com
Ram 1500 diesel,
Good evening! We wanted to bring you the latest JTops news!
The team has finally completed the design work and testing on the 2 and 4 door Bimini sun shades last week.
These shades are designed specifically to be left on under the hardtop of the Broncos. We incorporated a series of double-pull zippered access ports for the latches and small open ports for the hardware.
The shades are designed to sit on top of roll cage and provide complete coverage without gaps at the front, sides and rear. The front edge is our patented flip back design carried over from our Jeep line of products. It provides access to the windshield latches when putting the hardtop back on and flips forward when the hardtop is taken off. Then a series of Neodymium magnets do their magic and hold it firmly closed while the hard top is off. It's been tested to 85 MPH... after that you will be pulled over for speeding!
We put a lot of thought into every aspect of the shades. As we typically do, we focus on the overall look and then engineer a solution to make it work! We make sure that every design is done with the final look being one you will love to have on your Bronco!
Send us any questions or call us at 469-532-0808 for help. We will be updating the website www.broncosunshades.com with more pics over the weekend.
Pre-orders available now with shipping starting some time around May 9th. Use the forum member coupon code G625 for a $25 discount!
Here are some pictures of the 4 door off the Bronco and a 2 door on the Bronco.
—Mike Matras
Owner
—Helen Julson
Vice President/Director of Operations
Ford Bronco JTopsUSA Announces Bimini Sun Shades for the 2/4 door hard tops! 1651180757942
[email protected]
469/532-0808
http://www.jtopsausa.com
Ford Bronco JTopsUSA Announces Bimini Sun Shades for the 2/4 door hard tops! tempImageEoski2
Ford Bronco JTopsUSA Announces Bimini Sun Shades for the 2/4 door hard tops! tempImagerlJnOo
Ford Bronco JTopsUSA Announces Bimini Sun Shades for the 2/4 door hard tops! 1570A526-916B-4F73-82BF-2A0DB0CC4877
Ford Bronco JTopsUSA Announces Bimini Sun Shades for the 2/4 door hard tops! 94A65CB4-BA64-414B-9AA2-21E56E10B4E2
11Bronco1776
2021 Ford Bronco Badlands, 1994.5 F350 Powerstroke
Is this the hard top only model or also the updated soft top version that no longer is to cover the rear speaker boxes?
JTopsUSA
JTopsUSA
Ram 1500 diesel,
This is the hard top only model and it has the same new rear design as the soft top. Neither cover the speakers anymore. Still have a little curve but they perform better at speed.
Does this help?
Ford Bronco JTopsUSA Announces Bimini Sun Shades for the 2/4 door hard tops! 27F8BBFA-61FE-4DCA-9280-9457CD83CCB9
JTopsUSA
JTopsUSA
Ram 1500 diesel,
This is a no-drill required top correct?
Absolutely! We would never ever alter the vehicle in any way or require special tool or clips for installation. Just clean lines and strategically placed zippers for hardtop latch access
Need more info let us know!
Mike/JTopsUSA
11Bronco1776
Does this help?
Excellent thanks. Looking forward to mine. Already ordered the distressed flag. You and I have emailed back and forth a couple times. Thanks for you and your team's work on a quality product.
JTopsUSA
JTopsUSA
Ram 1500 diesel,
Your very welcome always here to help.
11Bronco1776
With the distressed flag what mesh do you use for the base for the graphic? I didn't see any option to select it and I assumed it's the black. I like the Titanium but not sure it mattters with a graphic.
JTopsUSA
JTopsUSA
Ram 1500 diesel,
Good question! We use a special white mesh that absorbs the ink. For years we printed on the color mesh but over time it would scratch off. Titanium was the worse!
The image can be seen from the interior as well but it’s dark on the subdued. It’s a crisper image and way more durable. It blocks 90% UV but is very transparent.
Here are a couple of pics. First is the subdued distressed and the second from the inside is the black and white tactical.
Does this help answer your question?
Ford Bronco JTopsUSA Announces Bimini Sun Shades for the 2/4 door hard tops! 0C0C24F9-85D1-4FB1-83A2-6BB174BD3A14
Ford Bronco JTopsUSA Announces Bimini Sun Shades for the 2/4 door hard tops! 369D81DC-3EAC-4702-A1EA-F144AC61CAF0
JTopsUSA
JTopsUSA
Ram 1500 diesel,
Do you do custom prints?
Thanks for your interest. Yes we do! Please contact Katie in our graphics department and she will work with you on your design.
Her contact email is [email protected]
We can do anything as long as it is nor copyright protected.
If I can help with more questions let me know.
Owner
JTopsUSA
Ford Bronco JTopsUSA Announces Bimini Sun Shades for the 2/4 door hard tops! 435277CF-D54A-4D66-9001-303C1FF732AD_1_105_c
Ford Bronco JTopsUSA Announces Bimini Sun Shades for the 2/4 door hard tops! 1C663586-5D25-476F-990F-0EC45C442DD6_1_201_a
TriggerTX
Trigger
Austin
61 Ford T-Bird, Autozam AZ-1, Golf R, Suburban 4x4
Looks like I know what bimini mine is getting when/if it's ever built. Sooo many possibilities. How will I choose the perfect design? :)
VelocityGator
98 4Runner
Ordered! Thanks for the discount code too. So excited for it to come in!
BlazinGTO
Dustin
MA
2004 GTO M6 2004 Escape
Approximately how long does it take when removing or reinstalling the shade?
