M&R Automotive 40" ROOF MOUNT LIGHTBAR KIT
MandRautomotive
Mikhail
CA
M&R brings you the Ford Bronco 40" roof mount kit. The light bar has 36 Cree LEDs. You will be able to order either White or Amber. The kit contains the bar, brackets, and mounting hardware. As with all of our kits, there is no cutting or drilling required. The kit is a complete bolt on using factory openings and hardware. The lightbar comes with 6.5 feet of wiring. That should be enough to tap it into the AUX switches if you vehicle is equipped with them. If not you can but a generic wiring harness on Amazon to control the light.
40 inch WHITE light bar
LEDs: 36pcs x 5W .
Power: 180 watt .
Luminous flux: 15,000 Lumens
40 inch AMBER light bar .
LEDs: 36pcs x 3W .
Power: 108 watt .
Luminous flux: 7000 Lumens
Bschurr
NY
MandRautomotive
MandRautomotive
Mikhail
CA
Nice job- Love that mounting solution because you can still use the caps to cover the bolts!
where can I buy them!
Exactly. The bracket is 11 gauge 1/8" that slides under the plastic base. The end result is it raises the cap by about 1/8" but still looks factory
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
Does it whistle from higher speeds?
Bschurr
NY
Do you sell just the mounts?
grayshadow
Charles
Humble, Texas
MandRautomotive
MandRautomotive
Mikhail
CA
  • Wow
Reactions: Cat
MandRautomotive
MandRautomotive
Mikhail
CA
i can but i do not guarantee fitment and clearance of the lightbar you are planning using. our bar is only 3/4" thick and we designed it to sit closeto the windshield and low profile
MandRautomotive
MandRautomotive
Mikhail
CA
From out testing it does not. There are no fins in our design of lightbars such as conventional lightbars
  • Like
Reactions: Cat
Perfect-Beast-2
Rick
Virginia and NJ
1973 F100 / 1980 F150 Stepside / 2019 F150 Lariat
If it’s the fins that whistle then I’ll cover them on my ‘other’ light bar. I do like these mounts though.
MandRautomotive
MandRautomotive
Mikhail
CA
Will it work with the roof rack?
no idea how the roof rack attaches but with the 1/8" added to the factory bolts that are sticking up, the thread is almost maxed out.
MandRautomotive
MandRautomotive
Mikhail
CA
Yours might not, but some of ours do.
Yea if yours has the aux swutches then you can definately use the existing wiring to power the lightbar
  • Wow
Reactions: Cat
