aj_benedetto
AJ
Harrisburg,PA
www.hoffmanford.com
2010 Honda Civic
Hello! My store recently replaced a MIC 1.0 top for one of our customers, and part of the replacement process required us to cut up the old top panels. Would anyone be interested in seeing the inside of the MIC top?
Edit: Below are some pictures that I took of the MIC 1.0. After inspecting the top and seeing just how thin that outer shell is, I can see why the honeycomb structure of the top was showing through when exposed to extreme heat/moisture.
Ford Bronco MIC Top 1.0 inside construction & material (cross section) - pics 2021 Ford Bronco MIC Hard Top 1.0 construction material cross section inside 3
Ford Bronco MIC Top 1.0 inside construction & material (cross section) - pics 2021 Ford Bronco MIC Hard Top 1.0 construction material cross section inside 4
Ford Bronco MIC Top 1.0 inside construction & material (cross section) - pics 2021 Ford Bronco MIC Hard Top 1.0 construction material cross section inside 5
Ford Bronco MIC Top 1.0 inside construction & material (cross section) - pics 2021 Ford Bronco MIC Hard Top 1.0 construction material cross section inside 2
Ford Bronco MIC Top 1.0 inside construction & material (cross section) - pics 2021 Ford Bronco MIC Hard Top 1.0 construction material cross section inside 1
jehines3
Easton, MD
Lexus RX350L, Chevrolet Silverado, Lincoln MKC
My understanding of all things internet. Without pics it didn’t happen.
aj_benedetto
aj_benedetto
AJ
Harrisburg,PA
www.hoffmanford.com
2010 Honda Civic
Pics are up!
GT500
Chuck
Maine
2018 Mustang GT
If this bothers you then you never want to visit an assembly plant to watch how your vehicle goes together.
aj_benedetto
aj_benedetto
AJ
Harrisburg,PA
www.hoffmanford.com
2010 Honda Civic
kodiakisland
Arkansas
Pretty sure that’s the same cellulose they put in shredded cheese.
Bronco21fan
Angelo
NewJersey
Why the fuck would they make a top out of cardboard couldn’t they just use like all plastic or even fiberglass
Dragline
GMC Yukon Denali, GMC Sierra 1500, Honda Civic, Chevy C3500
Weight. The core is essentially to give distance between the outer shell. The more separation between the top and bottom the greater the bending load they can carry.
j_marinelli
Spring Branch, TX.
They should of just used Amazon Prime boxes. Tops would of had a faster turnaround time doing that.
