- Fifteen52
- Jul 17, 2020
- 4
- 45
- 303
- Carson, CA
- Website
- fifteen52.com
- Coming Soon: 2021 Ford Bronco Outer Banks
- Outer Banks
a modern rendition of classic style.
Introducing the Analog HD, a modern rendition of classic style. As we continue in our journey to remap off-road performance for everyday use, we thought it'd be a good idea to bring back a classic steel wheel with some minor adjustments and added functionality. So we went to the drawing board and started with an all-aluminum construction to reduce unsprung weight, added some dimension to the center section that would channel airflow through the slotted pockets to your brake system, and included a reinforced flange design.
technicals .
DIAMETER | WIDTH | BOLT PATTERN | OFFSET | CENTERBORE | WEIGHT | LOAD RATING (LB) |
| 16 | 7.5 | 6x139.7 (6x5.5) | 0 | 106.2 | 23.46 | 2500 |
| 17 | 8.5 | 6x139.7 (6x5.5) | 0 | 106.2 | 27.50 | 2500 |
*** Please Note, we have not tested 16" on the Full Size Bronco yet, however we will have accurate fitment for 16" fairly soon ***
shop analog hd .
CLICK ANY WHEEL FOR MORE INFORMATION
HAVING TROUBLE? CLICK THESE LINKS: ASPHALT BLACK / CLASSIC WHITE / PEAK GREY
Get 10% Off Your First Set with: BRONCO6G
07/26 UPDATE:
We have a large Analog HD container landing Mid-August, as this is the most highly requested wheel for the full sized Bronco, please put in a pre-order to guarantee yourself a set. Thank you for your patience with us as we continue to deal with shipping and production delays.
Custom Ford Bronco on Analog HD in Classic White
Have Analog HD on your Bronco? Post it below!
