Protect Your Bronco's Paint from Rocks with powoq Mud Flaps
powoq
Lux Sponsor (Level 2)
LA
go.powoqoffroad.com
Hey Bronco family,
While the Bronco’s wide, off-road-ready tires look great, they also extend significantly past the fender flares. Because of this, the tires fling road gravel onto the rear doors and lower body. Without any protection, you’ll quickly start seeing noticeable paint chips and exposed metal.
To help protect your vehicle's exterior, we designed our mud flaps specifically for the 2021-2026 Bronco 2-Door/4-Door models (please note, these do not fit Bronco Sport models).
These mud flaps are designed to effectively block flying rocks, gravel, and road salt from hitting your paint, keeping your vehicle's exterior cleaner and better protected.
We constructed these using impact-resistant ABS plastic for the main flaps, supported by durable carbon steel mounting brackets. This combination provides a stable, secure fit that resists fading, cracking, or warping under various daily weather conditions.
Installation is straightforward and saves you the trouble of drilling. Additionally, to prevent vibration noise and protect your vehicle's paint, we include adhesive foam pads to be applied between the fender flares and the mud flaps.
You can grab a set here: https://bit.ly/4wvnyjp
