Camburg Billet Upper Control Arms
Camburg
Camburg
Huntington Beach
2020 Ford Bronco
Our Camburg KINETIK Series billet upper control arms for the Ford Bronco allow for increased wheel travel and articulation out on the trail, corrected suspension geometry with increased caster for improved handling both on and off-road and are considerably higher quality and higher strength compared to the OEM parts for off-road use.
These parts utilize our new Camburg X-joint XL for increased strength, longevity and high misalignment, allowing for maximum wheel travel. The larger X-Joint XL is an extreme performance, all-weather, all conditions, high angle ball joint. These are much higher quality, considerably stronger and have an improved boot design that allows for higher angle use, better greasing and increased longevity.
Camburg Bronco Billet Upper Control Arms
Camburg Bronco Raptor Billet Upper Control Arms
Camburg Bronco/ Bronco Raptor Suspension Systems
JF Bronc
Atlanta
Ford Bronco
Camburg team - please correct me where I’m wrong here, but I think one of the primary benefits a of a fully adjustable UCA like yours is that when you lift your Bronco and are running bigger tires like 37s, adjusting caster is more important (but also harder to do with standard components). Question - how much is too much caster with larger tires (37s) and what is optimal? Idea then is that your UCA helps achieve that optimal setup?
Brokenparts
Zach
Hillsboro, OR
1966 FJ45, 73 c-10, 79 Blazer, '23 Exp, 2008 F350,
Those are some amazing looking parts. Wish I the cash.
