stom_m3
Steven
2026 BRaptor on the way!
Working on my Bronco platform build for a Death Valley trip at the end of the month. I'm new to the Bronco (acquired in 2/28/26) and quickly realized that space is a premium. I was looking for a platform that gave me the ability to level out the back for sleeping, retain the ability to access the underfloor storage bin, have a fridge slide and cutting board, and be able to strap items down on the open side when not sleeping. Here are some pics of the current state and different parts of the build. In the end, the sleeping side is 24" wide which is plenty for me. I'm able to store my table underneath and still have access to the underfloor storage. The L Track works nicely to provide flexibility in mounting stuff. The Toughbuilt StackTech stuff fits perfect and has a pretty impressive feel. I ended up getting both the StackTech drawer and toolbox (lid on top) to see which version will work best for my use. I also added a Broaddict cargo shelf to increase usability. Works well. I may eventually get the BroAddict Traildeck but need to make sure I can mount a fridge slide to it.
Here's the finished product with toolbox.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4661-X2
How it started. I needed a 3" opening to be able to fit a table underneath the platform.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_1508-X2
Test fitting table and seeing how flat the sleeping surface will be.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_3129-X2
I wanted to make the support rails from wood but I couldn't think of a good way to be able to secure to the floor and platform at the same time. I was going to use aluminum C-channel extrusion but found rectangular channel in the scrap bin which was only $3/lb.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_3256-X2
Top view of the cargo area. I ended up putting the table on the driver side as I wanted to add a leg support under the sleeping side.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_3263-X2
My ultra expensive CAD system layout
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_3262-X2
Seeing what the cargo floor would look like.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_3259-X2
Top plate complete. Working on mounting the slides and checking clearance with the door mechanism.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4162-X2
Slides installed. Need to install tray and fridge top.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4228-X2
Added fridge tie down end pieces, carpet and EVA boat decking.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4249-X2
The clearance of door to fridge slide and fridge. Measure 20 times, cut once....
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4545-X2
Installed L-track and table guides underneath the platform.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4636-X2
Initial install and fit checks. I also added carpet runners on the cargo floor to cover all the exposed body.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4638-X2
Test fitting L-track. The StackTech is a little too wide to easily access the L-track. Will need to build a quick connect base for the StackTech stuff.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4641-X2
The fridge slide is 26" and the tray slide is 30". I was limited on the fridge slide because of the access points to the main rails which attach the platform to the chassis.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4643-X2
Installed the BroAddict cargo shelf. The fridge and StackTech boxes fit well. **whew**
Because I had issues accessing the L-track to strap the StackTech cases down, I made a mounting platform that mimic'd the StackTech base.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4684-X2
Test fitting new mounting solution.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4671-X2
Ended up buying the dual drawer as well to see if it worked better.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4680-X2
Overall, I'm happy with the results. I'm not sure if I'm going to use the StackTech drawer or toolbox. The drawer has a total capacity of 32L (16L per drawer). The medium tool box has a capacity of 40L, the small toolbox 22L. The large toolbox has 57L capacity but I did not buy that one as I thought I was going to run the small over medium together. As it turns out, it's a pain to have lids because they're stacked.
Once TrailRax gets the brackets complete for the painted roof, I'll be able to add a cargo box to the top which should alleviate some of the storage issues.
HalfmuleFarmer
Thomas
2025 Badlands
Nicely done. Any idea of your total added weight before passengers and cargo?
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
@stom_m3
Nice work!!!
Does it require you to remove the plastic door trim to remove the table?
Where do you keep the jack and if in the factory spot how do you access it?
I'm guessing that there is enough room once the table is removed to get the jack out. With the BA Offroad Traildeck you have to remove the jack a similar way and this setup gives just a little bit more clearance.
stom_m3
Steven
The total added weight with just the platform, rails, slides, tray, carpet is around 35lbs. The heaviest items are the stainless slides. Everything else is aluminum, carpet, or wood. The aluminum angle and rectangle is probably 8lbs. The wood is birch 1/2" ply. I'll measure it after the trip. I plan on taking in and out depending on the timing of my trips.
@stom_m3
Nice work!!!
No, the table lifts right out. I plan on accessing the table often and had to be readily accessible which is why I needed the gap to be a certain height to clear the table.
Correct, after you remove the table and carpet both jack and cargo bin are accessible. Granted you need to reach through the opening to do so. I keep recovery items and some tools in the cargo area. I'm assuming that if I have to access the area, it won't matter that I have to remove the table and carpet to access them.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4701-X2
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4702-X2
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4704-X2
Showing the rubber L-track covers for when I put the sleeping pad down and prevent cuts.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4706-X2
Showing the Big Agnes Campmeister. Removed both StackTech mount, and associated hardware. It's quick and easy.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4705-X2
Showing view from the other side of the air pad.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4707-X2
EveryDayBronco
Motorcycle
That reach to the jack looks tight but it looks like you have it figured out.
I've contemplated taking the passenger seats out to see if I could sleep in there, I'm 6'2"!
stom_m3
Steven
Oh that would be tight. I'm 5' 8" so not an issue. The Big Agnes air pad is 72". I haven't tried moving the seat all the way forward as well as tilting it forward. I'm almost positive that it would be more than 74" though. But there would be a small amount that would be unsupported so you would need to build a little platform for the second row fill. I'll try to measure it.
stom_m3
Steven
Ok measured. The max length from tailgate to passenger seat moved forward and tilted forward is 6' 8"
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4709-X2
The unsupported gap that you would need to make a platform is about 15". That said, you probably wouldn't need to fill the whole gap as the pad would do some supporting.
Ford Bronco My cargo platform solution build for overlanding (custom DIY) IMG_4710-X2
EveryDayBronco
Motorcycle
That's a 4 door, mine is 2 door!
