ptyyds
Lux Sponsor (Level 2)
Alex
For Bronco owners who frequently encounter changing road conditions, adding fog lights is a practical way to enhance both vehicle aesthetics and functionality. Our Fog Lights are specifically designed for 2021-2026 2/4 door Bronco (excluding the Bronco Sport). They complement the vehicle’s rugged lines while serving their purpose on the road.
The housing is crafted from ABS material, providing stability and resistance to water and corrosion. Paired with PC lenses, these units provide clear light output. This combination supports long-term durability while maintaining its appearance during outdoor use.
During normal driving, the lights emit a crisp white light to provide consistent visibility on the road. When the turn signals or hazard lights are activated, the system automatically transitions to amber yellow. These lights make the vehicle more visible to others in low-visibility environments, thereby improving driving safety.
The package includes the necessary tools and components for the setup. The design utilizes original factory mounting points and comes with a dedicated wiring harness, allowing for a plug-and-play installation, making the entire process easy.
Ready to upgrade? Pick yours up: https://www.amazon.com/dp/B0GLZ9BTDJ
JLC64UK
J
KY
24 Bronco Raptor, 23 Ford Expedition Timberline
Will they work with the dash switch or the aux switch on the Raptor?
DarthLincoln
Chuck
Northern California - Contra Costa County
1999 BMW M coupe, 2023 Ford Bronco Badlands 2dr
These apparently plug into the headlight connectors via an adapter harness:
They come on with the headlight’s DRLs so they are always on. That headlight adapter is also how they get the turn/hazard signal to flash amber. So you would have to modify the wiring to make them connect to the factory fog light switch circuit or wire to an Aux switch.
These appear similar to ones sold by Mabett. No information on brightness or if they meet SAE Fog light pattern.
BobbySaggz
East TN
'23 2DR Badlands 2.7AT; '24 2DR Badlands 2.3M/T
Who needs SAE beam patterns or power/lighting specs? Clearly these fog lights emit a crisp white light and complement the Bronco's rugged lines while serving their purpose on the road. They even improve driving safety because they're lights and they light up and they make you more visible to others when it's not light out.
Clearly every 2021-2026 Bronco owner (specifically excluding Bronco Sports because they're such similar vehicles and this forum is home to both) should buy these. You'd be a fool not to. Clearly.
TLDR: Adorn your 2021-2026 Bronco (not Bronco Sport) in Path Tough Your Daily Drive Support so you will have path easy and daily drive support. 💯
Astronaut
New Mexico
2017 RAM Longhorn Limited, 2024 Ford Bronco
It says the Mabett ones are a frequently returned item!
