ptyyds
Lux Sponsor (Level 2)
Alex
Hi Bronco fam!
If you’re looking to add a distinct look to your Bronco, our Trail Sight Lights are an addition to consider. They are specifically designed for the 2/4 Door 2021-2026 Bronco models (Not compatible with Bronco Sport).
These units utilize a die-cast aluminum alloy base, which provides a sturdy defense against rust and corrosion. A water-resistant lampshade covers the top, protecting the internals from the elements. It’s a setup built to handle rain on the trail without losing its finish over time.
The distinctive amber lighting gives your vehicle a unique appearance and makes it more visible on the road, especially in low-visibility environments. They don’t sacrifice the original utility, as they still function as tie-down anchor points. The installation is no-drill and plug-and-play, and the kit comes with all the tools you need.
Click here to check them out: Trail Sight Lights
SHANUT
Craig
Hermann, MO
I noticed when you use that link it also shows available fog lights for the upgraded factory bumper. The installation video shows a plug and play situation, but I’m wondering how you get all of the functionality out of those fog lights since the bronco doesn’t come with fog lights with that upgraded bumper and no switch comes with your kit.
MFM01
2024 Bronco
Do they function as turn signals as well?
hellerjames
James
Dillsburg Pa
2024 Bronco Badlands
When you do this change and plug your connections in please use some dielectric grease on the connections. I learned the hard way and almost had to replace the expensive headlights. Water got into the connections and corroded the terminals.
PolyTect
James
Sacramento, CA
This^^
Coming from a car with turn signal lights in the mirrors, having something someone can see when front and rear are out of view woukd be great. The fact the mirrors dont have this astounds me.
Wolfgang VTS
Terry
East Tennessee
2025 Bronco Base, 2021 Ford Ranger, 2022 Ford Bronco Sport
ptyyds
ptyyds
Alex
The fog lights connect to the headlight connectors via the included wiring harness and are controlled by the main headlight signal. This ensures they stay synced with the headlights. This way, it doesn't need a separate switch. I hope this helps!
ptyyds
ptyyds
Alex
ptyyds
ptyyds
Alex
ptyyds
ptyyds
Alex
Great tip! Thanks for sharing your experience!
