IAG Off-Road
JJ
Westminster, MD
www.iagperformance.com
We’ve just released our IAG Off-Road FMS Pod Light Mounts for 2021+ Ford Broncos equipped with the factory Capable bumper. If you want to add pod lights up front without drilling or permanently modifying your bumper, this setup was designed to bolt on cleanly and keep everything functional.
Ford Bronco New IAG FMS Pod Light Mounts for the Capable Bumper 1767710287586-ti
The Pod Light Mounts are part of our Functional Mounting System (FMS) and are sold as a pair. They attach directly to the IAG FMS Recovery Points, creating a solid, secure mounting location for most aftermarket pod lights while maintaining factory bumper integrity.
Ford Bronco New IAG FMS Pod Light Mounts for the Capable Bumper 1767710287693-2t
Bumper Compatibility
These mounts are designed specifically for the factory Capable bumper, which can be identified by the OEM D-rings.
If you’re unsure which bumper you have, our Bronco Bumper Breakdown blog walks through each option with photos.
https://iagoffroad.com/blog/bronco-...KXk-Q87jWVcoA9G0UeAFZjD1752s3jFazeTPMNjt8Yjzh
Built and Made in the USA
The IAG FMS Pod Light Mounts are designed and manufactured in Westminster, Maryland using 3/16” A36 carbon steel. They offer approximately 2.5 inches of adjustment space behind the mounting surface for flexible light positioning and are finished in a durable black powder coat for corrosion resistance.
Ford Bronco New IAG FMS Pod Light Mounts for the Capable Bumper 1767710287718-1j
Installation
Installation is straightforward and requires no drilling or cutting. The IAG FMS Recovery Points take roughly an hour to install, and the Pod Light Mounts bolt on in just a few minutes after that.
Ford Bronco New IAG FMS Pod Light Mounts for the Capable Bumper 1767710287782-k
Please note that IAG FMS Recovery Points are required and sold separately, and pod lights are not included.
IAG Off-Road FMS Pod Light Mounts For 2021+ Ford Bronco w/ Capable Bumper
IAG Off-Road FMS Recovery Point Set for 21+ Ford Bronco with Capable/Modular Bumpers
Tolzer
Gil
Kentucky
2026 Bronco
Very Nice!
I have the factory Capable bumper, and will be ordering your IAG Off-Road FMS Full Capable Bull Bar with Recovery Points Package. The bull bar does rest onto of the recovery points. It looks like your POD Light Mounts also rest on the recovery points. Will your POD Light Mounts with pods mount to your FMS Full Capable Bull Bar with Recovery Points ? It looks like the lights may not work with the vertical tubing on the bull bar?
Ford Bronco New IAG FMS Pod Light Mounts for the Capable Bumper Screenshot 2026-01-06 at 3.25.18 PM
Ford Bronco New IAG FMS Pod Light Mounts for the Capable Bumper Screenshot 2026-01-06 at 5.07.21 PM
AdamF@IAG
Adam
Maryland
iagoffroad.com
'22 Bronco Raptor, '21 Bronco 2 and 4 door, '24 Ranger Raptor
We have our stealth light mount that will work with that bull bar. BUT, you will be limited to a very slim LED light bar. The Rigid 20 inch SR series will fit for sure.
Ford Bronco New IAG FMS Pod Light Mounts for the Capable Bumper PXL_20250603_192411613.MP
JimboSlice
South Lake Tahoe, CA
2022 Ford Bronco Outer Banks 2018 Audi Q7
Can you flat tow the Bronco using these recovery points?
meyeracer06
Indiana
2022 Cyber Orange BD 7MT 4D
I have been deciding where/how I wanted to mount a pair of Diode Dynamics C2 2.0 lights, and this may be the ticket! I was looking at the mini bull bar, but this is an awesome minimalist option for us capable bumper folks! Thanks for the options!
Deputy909
George
Peoria, AZ
2015 F150, 2013 Traverse, 2007 Mustang Conv.
Installation
I have a 2025 Heritage and want to maintain that vibe will this system allow KC Dayliters to be used?
AdamF@IAG
Adam
Maryland
iagoffroad.com
It appears that the backspacing on the KC's would be no problem to fit on the Pod light brackets. The only thing I see that would need to be modified is the light through hole. The KC's utilize a 1/2" bolt, our hole is about 7/16".
Ford Bronco New IAG FMS Pod Light Mounts for the Capable Bumper 1767878564544-f1
CharlesBroncson
Will
What is the distance from each light through hole to the other? Just wondering if this would work on linkable pods as well.
AdamF@IAG
Adam
Maryland
iagoffroad.com
Center to Center is about 30-3/4"
