BroncoBuckaroo
Joe
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
A real life review after 4 years and 100,000 miles
Bronco Don
Don
Rialto, California
Tacoma 4x4
Good video but what kind of maintenance have you done on it? How often do you change your oil or what mileage ?have you changed the fluid in your transmission or your rear end or your front differential?
BroncoBuckaroo
BroncoBuckaroo
Joe
Missouri
full motorcraft synthetic every 5000-6000 miles, transmission fluid changed and diffs changed @ 60,000, original plugs and coils. I have a reusable air filter that I think I have cleaned 4 times.
I would not recommend full synthetic unless you drive a lot of miles per day (i Have seen some engine tear downs and seems to be detrimental unless the engine is well heated up for some time) better off using synthetic blend. But thats just the opinion of those tearing down the engines.
VirginiaHeritage
Frank
‘25 Bronco HE
Thanks for the vid. I’ll probably do plugs at 60k. Your take on synthetic vs. blend has the potential to set off an epic-length thread. I just assumed synthetic is always better so I’ll be following.
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
Yes, long time Amsoil dealer here. That's the first that I've heard that one, and I've heard a ton. It would have to be a very short drive not to bring it to temp. Not a dealer anymore so no dog in this fight. I use Mobile 1 full syn now, (big fight with Amsoil, great product, horrible policies) mileage depends on how much and how hard I tow, but typically 5-7K. Congrats on your 100K! I'm just under 50K on my 21. I changed all fluids except coolant at 1,500 and I have to say my manual transmission shifts beautifully.
jwysopal
James
Los Angeles
2021 Ford Bronco Black Diamond
Awesome!
I'm an early '21 build, and just hit 70K. No big issues ever since, maybe lucky, but my Bronco has been extremely reliable and easy to maintain with the 2.3T.
Techun
Pa
BD, 2.7, MIC, 4dr
50k+ on a 21. Did drive line fluids and an air filter so far...
BroncoBuckaroo
BroncoBuckaroo
Joe
Missouri
good idea on the plugs, again as far synthetic , that’s what I use. Saying that, I have watched several people who break down engines and they pretty much all agree that synthetic leaves a coating on engines when driven in a way that doesn’t allow extended operation that holds proper temperature.
so I’m not recommending one or the other (do your research is what I say). But again I do use Motorcraft Full
Thanks Tonka Bronco,
I was impressed for a new model, especially with all the limitations on chips and such in that manufacturing year.
BroncoBuckaroo
BroncoBuckaroo
Joe
Missouri
Sgt Badlands
Joe
Midwesr
Where are all the full synthetic guys who say you are going to destroy your engine with semisynthetic that is recommended by Ford?? 🤣🤣🤣🤣🤣🤣
  • Like
Reactions: Cat
Sgt Badlands
Joe
Midwesr
Why plugs at 60k when Ford recommends at 100k or above?
VirginiaHeritage
Frank
‘25 Bronco HE
Ford says 60k under certain Special Operating Conditions.
Maybe I’m a Special Operator, operating operationally.
Techun
Pa
BD, 2.7, MIC, 4dr
How is access to the plugs?
I just did them on my 93 c4 and it scarred me terribly.
