Everglades wheels on a carbonized grey BD?
tylerca
Will
Tampa
f150
Just an FYI if you didn't know, the EG wheels do look good but with the new Job 2 change over to the Sasquatch package the EG wheel is going to be the default so from J2 forward every Sasquatch package Bronco is going to have these unless they "upgrade" to the previous standard bead-lock wheel.
I did see that upcoming change, and as much as I originally liked the SAS wheels, I am growing weary of them in my area - prob 80% of Broncos in the Tampa area are SAS. Hopefully the Everglades wheels on the SAS is short term......
tylerca
Will
Tampa
f150
Different finish to them and the angles of the truck vs the angle of the wheels makes them stand out differently and not look all the "same color". It will look good, dont second guess yourself now. Side note, if its hard to find images of it, its not overdone and likely a fairly original idea!
The slight change in color that I perceive in the photos was a big factor - they appear darker in most pics
Summit981
Paul
Maryland
Porsche Cayman, MINI GP2, MINI Countryman
Should look good I have them on my Area 51 badlands.
Sounds like a good combo. Got a picture of the truck with those wheels on? (My BL 4-door is Area 51.)
Bronc6g22
Jake
Washington
Mazda 6, Tacoma TRDOR
Here is my Area 51 BL with EG wheels.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I’ve wondered what they would look like on Iconic Silver…
Summit981
Paul
Maryland
Golfsnob
St Augustine
2023 Base 2 Door, Manual, 2.3
Bschurr
NY
Rumbloki
Alton
ATX
ZR2, 1973 Mach 1
I can't remember who this belongs to.
Ford Bronco Everglades wheels on a carbonized grey BD? 35X11.5 TOYO OC AT3 on Stock Badlands No Lift EG
redone17
Cold Spring, NY
It’s funny they call it carbonized gray and it’s clearly a different paint. Seems darker.
JohnnyX
Pentwater, Michigan
2008 Ford Explorer
I agree with redone17... Saw a couple at the LV Off-Roadeo this Friday. Definitely looked darker to me, even up close. They were on EG Everglades...
Bschurr
NY
They are 100% not the same color as the vehicle!
redone17
Cold Spring, NY
Making me think they’ll look great on Iconic Silver.
